Straight thread. clean the adapter and MC threads (easy) with a wire bristle brush then lube em & visual on the threads for any damage. the 9/16 adapter might be 18 threads instead of 20 like I first posted but its a brake line inverted flare adapter so it is the correct one. EDIT while we are at it measure the # of threads on the adapter with a 6" thin steel scale ruler or a thread pitch gauge if you have one. The # of thread "peaks" in an inch so we can be straight on that
