xfer ID and fluid change? #2003270
02/01/16 11:24 AM
02/01/16 11:24 AM
scratchnfotraction Offline OP
what fluid does the 98 jeep GC quadratrac 249 case use?
I assume this is the 249 case, it has 240-1 on the id tag so not 100% on it. seems to be HI-N-LO (I have not been able to shift it yet, both engine and trans mounts are shot and has linkage pulled out of bushing/alinement.
I have been reading but cant seem to find much for type of fluid.
also, I see the fill/drain plugs on the back of case. is there any other drain spots that need to be opened?
I watched a video and 1 plug had a spring/plunger piece for a detent maybe? will this plug remove the last of the fluid?
TIA
Re: xfer ID and fluid change? [Re: scratchnfotraction] #2003925
02/02/16 01:47 AM
02/02/16 01:47 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
There is a tag on the back of it, about the size of a silver dollar with the info stamped on it. most new transfercases use atf
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: xfer ID and fluid change? [Re: astjp2] #2004452
02/02/16 10:57 PM
02/02/16 10:57 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Should use special fluid not ATF on a quadratrac i think Mopar calls it 249 fluid.
that said I just check Mopar web site ;
MoparĀ® Dexron II, or ATF Plus are the only lubricants recommended for the NV249 transfer case. Approximate fluid refill capacity is approximately 1.18 liters (2.50 pints)
I don't know??
Re: xfer ID and fluid change? [Re: SALEM1912] #2004489
02/02/16 11:57 PM
02/02/16 11:57 PM
IN
ahy Offline
ahy  Offline
IN
QC is a nice system IMO. Also touchy about lube. Front and rear diff take Mobile one gear lube + limited slip friction modifier.
Not sure on the transfer case. It might be best to get it at the dealer based on VIN to get the right stuff.
Re: xfer ID and fluid change? [Re: ahy] #2004635
02/03/16 03:58 AM
02/03/16 03:58 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
This is the stuff I always used; http://www.ebay.com/itm/like/161948594088?ul_noapp=true&chn=ps&lpid=82 fill plugs transfer case
Re: xfer ID and fluid change? [Re: ahy] #2004744
02/03/16 12:43 PM
02/03/16 12:43 PM
THANKS, this is what I am looking for. I pick3 bottles up today at the dealer.
I found the drain/fill plug on the rear of the case, and also found the tag.
but the # on the tag is 240-1 so I am not sure if that is the 249 full time or if it has been replaced with something. I do see a bar code tag on the xfer and will check at the dealer to see what they can tell me from a vin#.
it does have a SG in the rear so I will get the oil along with the xfer fluid.
might as well do a trans filter/pan gasket while I am under there. seems it uses the ATF+ for fluid.
is there any other bolts/plugs to drain the last bit of fluid?
I know on my 79 RC 203 you removed the lowest bolt on the front output cover on rear of case to get the last 1/2 quart out.
Re: xfer ID and fluid change? [Re: scratchnfotraction] #2004800
02/03/16 02:15 PM
02/03/16 02:15 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
what that tag should show is NV249J
There is no 240 t case
249- 2 speeds, 4 strength rating, 9 - viscous coupling
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: xfer ID and fluid change? [Re: ViperDave] #2004929
02/03/16 05:05 PM
02/03/16 05:05 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
No
Re: xfer ID and fluid change? [Re: ViperDave] #2006764
02/06/16 03:03 PM
02/06/16 03:03 PM
I had a better look with spy glasses and it indeed has 249J on the tag.
