Hello Could someone please help me. I put a new MP master cly on my 1973 Pro Street Duster.How do the brake lines run .Dose the front line on the master cly go to the top of the port valve ? And the rear line on the master cly go to the bottom of the port valve ? That is how I have them now . I had someone said that they was wrong .The front line should go to the rear of the master cly. . Thanks mosweethemi
Normally the front brakes goes to the rear of the
master and rear brake line goes to the front...
if your running disc front drum rears... but if
you run BIG tires on the rear and skinny fronts
you might want to swap them.. the disc fronts
normally do 70% of the braking.. but with skinny
tires you want the rears to do 70% or more so
you dont just lock the fronts on a semi normal stop
