explain Carb annular booster vs 3 circuit annular #2002531
01/31/16 09:54 AM
01/31/16 09:54 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
What's the difference between the annular booster and a 3 circuit annular booster carburetor?
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2002601
01/31/16 12:57 PM
01/31/16 12:57 PM
Mark Whitener Offline
Annular 2 vs 3 circuit refers to the addition of an intermediate circuit. It is a discharge tube placed about half way between the venturi, minor diameter of the throat, and the throttle shaft. It adds the most fuel at part throttle, but still contributes at WOT. It was designed to be used for an individual runner application, when pulses from the runner are so high they disrupt part throttle booster operation. 4 and 6 cylinders can benefit even with a plenum as pulses are strong. I have found only rare occasions that need a third circuit.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2002988
01/31/16 10:45 PM
01/31/16 10:45 PM
AndyF Offline
AndyF  Offline
Here is a picture of annular boosters. The fuel comes out of the tiny holes inside the booster.
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2003023
01/31/16 11:20 PM
01/31/16 11:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Andy, do you have a pic of that adapter off the manifold?
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2003135
02/01/16 01:16 AM
02/01/16 01:16 AM
AndyF Offline
AndyF  Offline
Here is a close up. It is fairly simple open to open with just a slight taper outward.
Re: explain Carb annular booster vs 3 circuit annular [Re: AndyF] #2003391
02/01/16 02:20 PM
02/01/16 02:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I just tested the 850 on my car last week and holy chit it was way responsive but WAY too much emulsion and WAY lean down low so after tweaking it, it rocks but it just had the stock down leg boosters........
Re: explain Carb annular booster vs 3 circuit annular [Re: Thumperdart] #2003407
02/01/16 02:40 PM
02/01/16 02:40 PM
Ohio
lockjaw-express Offline
Ohio
Thumperdart and all,
When would you recommend an Annular Booster over the smaller down-leg booster?
Also, I run my engines in a Strip/Street configuration, so would two smaller CFM Annular booster carbs in a dual quad configuration be correct? and would a low vacuum signal be another reason for Annular boosters?
Thanks!
Re: explain Carb annular booster vs 3 circuit annular [Re: lockjaw-express] #2003414
02/01/16 02:53 PM
02/01/16 02:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I havn`t changed em out but Mark W. is the guy to ask so hopefully he`ll chime in. I know that the annulars give a cleaner perimeter fuel spray instead of wicking like a downleg does and apparently automized better.......
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2003469
02/01/16 03:56 PM
02/01/16 03:56 PM
AndyF Offline
AndyF  Offline
Mark changed my 950 over to annular boosters because I was running a low RVP fuel in cold weather. The change to annular boosters picked up a lot of torque down low (20 to 30 ft-lbs) but the carb didn't make anymore power up top.
I'll rerun the tests this summer to see if the torque advantage stays there or if it is a cold weather thing only.
Re: explain Carb annular booster vs 3 circuit annular [Re: AndyF] #2003477
02/01/16 04:02 PM
02/01/16 04:02 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Thanks for the info. I do run an annular booster now, needed to know if the 3 circuit was worth getting. Never ran one before.
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2003485
02/01/16 04:07 PM
02/01/16 04:07 PM
AndyF Offline
AndyF  Offline
If you're asking about a Dominator then I'd recommend sticking with a 2 circuit carb. The third circuit can be handy for specialized applications but for the average guy it just dumps extra fuel into the intake and causes problems. I think Holley should stop selling the three circuit carbs and offer them only as a special option but I'm guessing they don't worry too much about my opinion!
Re: explain Carb annular booster vs 3 circuit annular [Re: AndyF] #2003504
02/01/16 04:21 PM
02/01/16 04:21 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i agree! if ya do have a 3 circuit thats giving you fits try running carb without int. air bleeds or i have found a 90-100 air bleed helps.
Re: explain Carb annular booster vs 3 circuit annular [Re: AndyF] #2003516
02/01/16 04:38 PM
02/01/16 04:38 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most racers and builders prefer the 3 circuit and we sell a LOT of them, especially for STOP racing. We offer both and with different options. It's up to the consumer to either KNOW what he needs, or call the tech line and get some help. But why would we stop making something just because many don't understand them or what they need
We have had this debate several times. A few builders like Mark, prefer 2 circuits and that's fine. But more yet prefer 3 or more circuits. Does it take more understanding to make it work at part throttle?.......yes, without a doubt, but if you know what you are doing, they work just fine. NOT suggesting that Mark or anyone else doesn't understand..........they just prefer the 2 circuit. I am sure he can make a 3 work as well as anyone else can.
I just watched Mike Laws personally tune a 3 circuit on a 170+ mph Super gas combo at Orlando. Watching the car and looking at data, he made the curve silky smooth and a lot of that was done on the 3rd circuit
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2003535
02/01/16 04:55 PM
02/01/16 04:55 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I'm sure tthis will sound like a broken record, as I've both stated and asked, if the metering blocks still have the idle fuel supply in the main well. THIS, is the design flaw to beware of. Anecdotal. 🙈
Re: explain Carb annular booster vs 3 circuit annular [Re: Leigh] #2003574
02/01/16 05:48 PM
02/01/16 05:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It`s been well documented that even if you plug the int. circuit on the 3-circuit blocks, the main well can`t flow enuff fuel due to the emulsion tubes as they take up needed space/volume and why guys go w/the BLP widebody blocks............
Re: explain Carb annular booster vs 3 circuit annular [Re: Thumperdart] #2003599
02/01/16 06:27 PM
02/01/16 06:27 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I understand this, and went 2 circuit because of this problem. I want to understand why Holley made them that way to begin with. Every 3 circuit success story, seems to inclube BL metering blocks. Only my experience, of course😉
Re: explain Carb annular booster vs 3 circuit annular [Re: Leigh] #2003612
02/01/16 06:41 PM
02/01/16 06:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Change to a 2-circuit block and problem solved........
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2003665
02/01/16 07:48 PM
02/01/16 07:48 PM
Ohio
Ohio
Hi 68dodge,
What size carb are you running or planning to run? And is this a strip car or Street/Strip?
I am also interested in your questions, as I was looking at the Quick Fuel 750 SS Carbs w/annular boosters for a dual quad in a progressive linkage.
Since I am running on the street some, I thought of running the above carbs instead of a QF Dominator 1400 CFM...same cfm, but would be more streetable??? maybe???
Mark
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2004097
02/02/16 02:10 PM
02/02/16 02:10 PM
Annular boosters provide superior atomization of the fuel, this leads to more equal distribution. For a 4150 as long as the carb is sized to offset the airflow difference then peak power will not be hurt. There are also options available like the custom annulars in Andy's 950 on page one, BLP also has a custom mini annular that installs in a modified Braswell down leg booster that works well. Also with the annular it allows a larger carb than normal to be used, this can improve power across the board.
As far as the intermediate circuit it is rare that you need it when the carb is tuned correctly. There are cases with a throttle stop where it can be useful, when an under carb stop with 1 to 1 linkage is used the blades may be closed too far to get a consistent signal to the boosters to meter well. And most of the time with the 1 to 1 linkage it's on a larger engine that has to close the blade a lot to get the stop RPM down where they want. With a progressive linkage under carb stop or inline linkage stop it isn't an issue, and the intermediate can actually hurt. I do have several guys running 2 circuit carbs with 1 to 1 stops with no issues, so it's just dependent on the combination. For anything bracket raced or run on the street there is no reason for it at all. My feeling is the more fuel you run thru the booster the better atomized the fuel is, the better distribution is, the more fuel gets vaporized early lowering induction temps... more overall power.
Mark Whitener
Re: explain Carb annular booster vs 3 circuit annular [Re: 68dodge] #2004209
02/02/16 04:24 PM
02/02/16 04:24 PM
AndyF Offline
AndyF  Offline
I have some 2 vs 3 testing scheduled for later this year. My 1250 has been modified by BLP with the upper fuel jet modification and extra metering blocks so I can switch back and forth between 2 circuits and 3 circuits.
BLP provided me with multiple setup sheets so I can run the carb either way. I just pull the jet area out of the intermediate circuit and route it thru the main circuit by using a larger main jet and larger upper fuel jet. So then we can see the power difference between dumping the fuel from the intermediate nozzle or having it flow thru the boosters.
