metal portion of distributor cap burns away in no time #2002394
01/31/16 12:45 AM
01/31/16 12:45 AM
Louisiana
duckblind Offline OP
Louisiana
I have a mallory unilite distributor on a 440. The metal portion of the distributor cap that passes the charge to the rotor burns up really fast. I would say today it burnt up around 1/4" in a 40 mile drive. Any ideas what is causing this? Would it be the ignition module in the distributor or something else?
Re: metal portion of distributor cap burns away in no time [Re: duckblind] #2002401
01/31/16 12:50 AM
01/31/16 12:50 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It sounds like there is a gap between the rotor tab and the cap button. Is it the correct parts?
Re: metal portion of distributor cap burns away in no time [Re: duckblind] #2002404
01/31/16 12:52 AM
01/31/16 12:52 AM
make sure the rotor center "tang" has a bit of tension so it compresses a bit when you install the cap down on it. If there is a gap the arcing will burn the surroundings in no time. also you might put a slight bit of dielectric grease on the top of center tip of the brass rotor tang where it contacts the underside of the cap, the area in question. Helps with radio static also. EDIT Morty beat me to it
Re: metal portion of distributor cap burns away in no time [Re: duckblind] #2002416
01/31/16 01:08 AM
01/31/16 01:08 AM
Louisiana
Louisiana
I think they were the correct parts. The rotor and cap were both mallory. I will order a new cap and make sure there is tension between the rotor and cap. I will also put some of the dielectric grease. I need to order a new cap because the metal has been eaten all the way up into the cap. Thanks for the advice.
Re: metal portion of distributor cap burns away in no time [Re: duckblind] #2002448
01/31/16 01:54 AM
01/31/16 01:54 AM
Cab_Burge Online work
Cab_Burge  Online Work
Mallory Unilites use to suffer a lot of lights out failures,(the LED failed) usually half way to nowhere shruggy Maybe now is the time to switch ignitions to a better more reliable brand and type twocents Is the positive lead to the coil the 12V source and does the negative side goes where it is suppose to workIf they're reverse it is possible that is causing the problem with your center electrode scope
Re: metal portion of distributor cap burns away in no time [Re: duckblind] #2002526
01/31/16 09:27 AM
01/31/16 09:27 AM
Louisiana
Louisiana
I don't think I have the positive and negative reversed but I will double check and make sure that I don't.
Re: metal portion of distributor cap burns away in no time [Re: duckblind] #2002587
01/31/16 12:28 PM
01/31/16 12:28 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I was burning center electrodes in the caps because of a hot MSD ignition running too much spark plug gap.
Re: metal portion of distributor cap burns away in no time [Re: markz528] #2002883
01/31/16 08:37 PM
01/31/16 08:37 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: metal portion of distributor cap burns away in no time [Re: Joesixpack] #2002884
01/31/16 08:38 PM
01/31/16 08:38 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: metal portion of distributor cap burns away in no time [Re: duckblind] #2002929
01/31/16 09:42 PM
01/31/16 09:42 PM
Andrewh Offline
Andrewh  Offline
the unilite I have doesn't have a metal portion in the center.
It has a carbon rod.
very easy to break off and arc to the rotor if it is missing.
it will burn out the unilte electronics as well if you leave it like that.
perhaps they changed it since I got mine.
Like this one.
I burned out 3 before they figured out I snapped the center off.
