High beam delete for you electric guys #2002661
01/31/16 02:37 PM
01/31/16 02:37 PM
Chicago-area Illinois
4mopower Offline OP
4mopower  Offline OP
I was looking to delete the brights switch from the floor in a street rod and was wondering if anyone has tried replacing the light switch with a 4 position one to add the brights too? Whos did you use?
Re: High beam delete for you electric guys [Re: 4mopower] #2002703
01/31/16 03:33 PM
01/31/16 03:33 PM
Speedway mtrs has alot of street rod stuff & might have something in that area
Re: High beam delete for you electric guys [Re: 4mopower] #2002856
01/31/16 07:39 PM
01/31/16 07:39 PM
I think a proper amp rated three way switch should work, low beams are one element iluminating and high beam is two elements burning in the single headlamp systems, correct scope shruggy Dual headlights is one bulb on for low and both on for high beams, correct work
Re: High beam delete for you electric guys [Re: RapidRobert] #2003272
02/01/16 11:25 AM
02/01/16 11:25 AM
moparx Online content
moparx  Online Content
they sure do !
#910-80154 $31.95 ea.
4 position
3/8"hole
[in]off/notch #1park lights/notch #2 low beams/ notch #3[all the way out]high beams
screw type terminals also looks like the knob is held on with a set screw making it easy to change to a matching knob for your existing knobs if necessary.
beer
Re: High beam delete for you electric guys [Re: moparx] #2004529
02/03/16 12:44 AM
02/03/16 12:44 AM
4mopower Offline OP
4mopower  Offline OP
Thanks guys I'll check out the link.
