Re: 70 E Body Oil Pressure Gauge dead
[Re: Sammy]
#2002665
01/31/16 02:40 PM
01/31/16 02:40 PM
RapidRobert
seperate the bulkhead & ground that wire in the rear bulkhead half & see if the gauge swings over. www.mymopar.com will have the schematics/colors for you. EDIT no go there? then go further upstream to the round connector on the printed circuit (The dash (likely) needs to come out to access that area) & there might also be an open on the power in feed side of the gauge in the printed circuit. I'd ohm the pins for continuity & be carefull pulling the round connector off of the pins (back it off/out evenly). Holler what you find. MORE EDIT Ohming will tell you if the gauge itself is dead & the more I think about this the more I think that the erratic behaviour symptoms would likely have to be the gauge or the sender, much more likely the gauge (like a tach that acts up the same way) and we confirmed the sender is OK
[Re: 1970A66]
#2002939
01/31/16 09:52 PM
01/31/16 09:52 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
There is no circuit board on the E body gauge cluster FYI.
The wire from the sending unit goes from the bulkhead connector straight up to the back of the oil gauge. This wire has a 90 degree push on connector at the oil gauge. Maybe it came off?
Since grounding the sender wire didn't peg the gauge upscale then we know the sender is not the problem. You could inspect the bulk head connector for a bad connection as Robert said. Maybe ground the oil gauge wire there if you can identify it but that isn't easy in that mess of wires.
Another option, reach up under the dash and feel for the 90 degree connectors (plural) on the back of the oil gauge. Make sure they are pushed on tight. One is from the bulkhead and the other is from the voltage limiter which supplies the 5v power to the gauge.
If all the above is OK I'd pull the 90 degree connector off at the back of oil gauge(the one from the bulkhead) and ground the oil gauge stud momentarily to see if it pegs upscale. Thankyou, going to go do this now and see, I tried to look up under the dash but it is tight under there and hard to see the back of the gauge. Also going to check the bulkhead connector too.
