Page 2 of 3 1 2 3
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1938882
10/26/15 12:55 PM
10/26/15 12:55 PM
Must say, wow! The rate of response in this forum is incredible. I'd have to wait 5 days in the other forums for all these responses. I'm impressed and humbled. Thanks, guys.
Hey We're the best, F the rest!. You know what I'd do now is take out the stat housing/stat/fan belt & fill the housing neck up to the brim with coolant & start it & power brake it & see if you see bubbles or the coolant starts to rise. You only have a brief window of several minutes give or take till heat expands the coolant the same way (wouldn't be bubbles tho) but if it bubbles or rises right off the bat within several minutes then that is a dead giveaway for you know what. Good point missed earlier & that is to put on a non recovery cap then pump it up to 15 then you will have a sealed system that ain't going nowhere unless there is a leak in the rad, in the hoses, in the pump (all external) or internal/inside in the head gasket (BB) or head gasket and or intake gasket (SB) & alot of those recovery systems dont work right in the first place (they dont end up drawing the coolant back to the rad) so pumping up a recovery cap system overnight ends being a valid test by default
Re: Newbie with myterious coolant loss [Re: RapidRobert] #1938895
10/26/15 01:18 PM
10/26/15 01:18 PM
Atlanta, GA, USA
Dodgevity Offline OP
Atlanta, GA, USA
Originally Posted By RapidRobert
[quote]Hey We're the best, F the rest!. You know what I'd do now is take out the stat housing/stat/fan belt & fill the housing neck up to the brim with coolant & start it & power brake it & see if you see bubbles or the coolant starts to rise. You only have a brief window of several minutes give or take till heat expands the coolant the same way (wouldn't be bubbles tho) but if it bubbles or rises right off the bat within several minutes then that is a dead giveaway for you know what. Good point missed earlier & that is to put on a non recovery cap then pump it up to 15 then you will have a sealed system that ain't going nowhere unless there is a leak in the rad, in the hoses, in the pump (all external) or internal/inside in the head gasket (BB) or head gasket and or intake gasket (SB) & alot of those recovery systems dont work right in the first place (they dont end up drawing the coolant back to the rad) so pumping up a recovery cap system overnight ends being a valid test by default
Unfortunately, the 4.7 thermostat and housing sits at the bottom where the lower rad hose meets the motor. If I removed it, all coolant would drain out. The non recovery cap comment, I don't understand. Sorry, but this is where the newbiness shows. LOL Wouldn't the pressure tester's cap be considered a non-recovery, since it has no valves? Currently I'm pumping it up to 21 PSI, since that's the max pressure on the cap.
2003 Dodge Dakota Quad Cab SLT
4.7L V8, Automatic (545RFE), RWD
310K mi
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1938905
10/26/15 01:34 PM
10/26/15 01:34 PM
Yes you are correct! A brain fart on my part.
Re: Newbie with myterious coolant loss [Re: RapidRobert] #1938997
10/26/15 04:14 PM
10/26/15 04:14 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Were the best, F the rest.....LOL
Re: Newbie with myterious coolant loss [Re: minivan] #1939017
10/26/15 04:48 PM
10/26/15 04:48 PM
Atlanta, GA, USA
Atlanta, GA, USA
You guys are a trip... I think I'm going to like this forum. grin
A few pics of the old battle axe that won't quit.
310K mi
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1939908
10/27/15 09:42 PM
10/27/15 09:42 PM
Atlanta, GA, USA
Atlanta, GA, USA
Well, guys.
I can definitely rule out the overflow tank and hose as having a leak or being faulty. The only thing left is head gasket, but I think I can almost rule it out too. I went through some steps from the service manual, including hooking up the tester, pumping to 16 psi and revving in place. Manual says if gasket was perforated, the revving would have caused pressure fluctuation. The needle was rock steady, and rising slowly with heat expansion. Furthermore, I smelled the exhaust and not a hint of coolant. If anything, a little water vapor with the cold weather. Heater core is dry too and there is not a single drip anywhere. Still, the coolant does not seem to be returning from bottle, so it must be losing the vacuum effect somewhere.
I'm totally baffled at this problem. W-T-F? LOL
310K mi
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1939915
10/27/15 09:50 PM
10/27/15 09:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
headgaskets can leak into the oil pan and not the combustion chamber, how's the oil level look? See any milky residue at the fill cap?
Does you new cap work properly when the system cools downn, creates a vacuum and tries to suck coolant back into the system?
Don't be the exception.
Re: Newbie with myterious coolant loss [Re: Supercuda] #1939921
10/27/15 09:58 PM
10/27/15 09:58 PM
I'd get it hot & pump it up to 15 & let it set overnight. If it ain't leaking externally then it has to be leaking inside the eng
Re: Newbie with myterious coolant loss [Re: Supercuda] #1939926
10/27/15 10:04 PM
10/27/15 10:04 PM
Atlanta, GA, USA
Atlanta, GA, USA
Cap is a week old. Nothing changed when I replaced it. I just took this....
310K mi
Re: Newbie with myterious coolant loss [Re: RapidRobert] #1939934
10/27/15 10:07 PM
10/27/15 10:07 PM
Atlanta, GA, USA
Atlanta, GA, USA
I pumped it up hot just now. Pressure drops as it cools, which seems normal. If I pump it up cold, pressure holds for a long time. I will pump it up and leave overnight.
310K mi
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1939940
10/27/15 10:13 PM
10/27/15 10:13 PM
actually not normal. when pumping it up when hot then the pressure starts to drop not because it is cooling off but because the HG is leaking. pumping it up when cold would highly likely leak if let set up overnight (just takes longer to develop when the eng is cold). Supercuda has you covered in his last post
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1939941
10/27/15 10:13 PM
10/27/15 10:13 PM
Atlanta, GA, USA
Atlanta, GA, USA
And no oil in coolant...
310K mi
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1939945
10/27/15 10:18 PM
10/27/15 10:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Oil and coolant look good, so that leaves the new cap. Does your tester also have a vacuum function to test the cap and make sure it'll draw in coolant under a vacuum?
If so test it, if not I would suspect the cap of not doing it's job even if it is new.
Re: Newbie with myterious coolant loss [Re: RapidRobert] #1939951
10/27/15 10:29 PM
10/27/15 10:29 PM
Atlanta, GA, USA
Atlanta, GA, USA
I'm sure if I leave it overnight, it will lose some pressure, but according to everything I've read, the system is not expected to hold perfect pressure with a tester attached all night. I've left it for an hour and lost less than a PSI (cold). Most say if the pressure does not drop much in 20 minutes, there is no leak. Remember, cooling overnight should create pressure drop enough to create a vacuum.
If I pump it up while hot, I'm combining thermal expansion with air pressure from the pump. As it cools, pressure will drop due reducing thermal expansion, till the expansion is no longer a factor and that would leave only the air pressure...so there would be a considerable pressure drop.
With the tester attached, I found a minute leak which I never saw under normal operation (last week). I fixed those with heightened hopes, only to be disappointed.
310K mi
Re: Newbie with myterious coolant loss [Re: Supercuda] #1939955
10/27/15 10:35 PM
10/27/15 10:35 PM
Atlanta, GA, USA
Atlanta, GA, USA
Nope...wish it did. frown
310K mi
Re: Newbie with myterious coolant loss [Re: Dodgevity] #1940024
10/28/15 12:10 AM
10/28/15 12:10 AM
Alright how about this, pump it up stone cold to 15 & let it set overnight & if it drops to say 10 then we have lost 5 lbs of psi somewhere & now that might be 5lbs of air at the top of the system or coolant in the rest of the system or a combo of both but we ARE losing coolant & tho you and me neither want it to be a HG issue, that 5 psi loss (& some if not all is coolant cuz we are losing it) then it has to be going somewhere
Re: Newbie with myterious coolant loss [Re: RapidRobert] #2002604
01/31/16 01:00 PM
01/31/16 01:00 PM
Atlanta, GA, USA
Atlanta, GA, USA
Hate to leave a thread hanging so I thought I'd come back and update and to let you know you guys were right. I finally ran a chemical test on the block and it failed. Video below.
I ran a second chemical test yesterday with the truck hot, and the fluid quickly changed to yellow without me having to raise the RPMS like I did in the video.
I still don't understand what caused the issue though, as I never overheated this truck and checked fluids anally. Again, truck runs and idles perfectly. No smoke and no overheat. No oil in coolant or vice-versa and pressure tests were passed. No bubbles in coolant, etc. Obviously though, exhaust gases are in the coolant. So it might be a cracked block, cracked head or bad HG.
So there it is... "head gasket" failure. I was driving the truck daily till diagnosis. Now, I drive it only a few miles on weekends to keep it from sitting too long. Waiting until the weather gets warm to work on it. Don't want to get worse. Hate to say this, but I'm going to try using block sealer first. I think with such a mild condition it may work. Will bypass heater core when I do this. Got this truck cheap and the miles are pretty high. Don't know if digging into it and possibly finding a cracked head or block is worth the investment. Plus I'd have to change the timing chains too.
310K mi
Re: Newbie with myterious coolant loss [Re: Dodgevity] #2002632
01/31/16 01:39 PM
01/31/16 01:39 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I just saw this thread. As soon as the pressure tester went to 23psi there was your answer. How can a 15lb cap seal 23psi? It can't. Thus the coolant fills the overflow bottle. After working in dealerships over 27 years I can tell you head gaskets fail on a regular basis w/o being overheated. All types of engines.
Doug
Re: Newbie with myterious coolant loss [Re: dvw] #2002637
01/31/16 01:47 PM
01/31/16 01:47 PM
Atlanta, GA, USA
Atlanta, GA, USA
Doug
I don't understand your theory. The pressure tester's cap replaces the vented cap. The pressure tester has no vent to expansion tank. The pressure can rise till the hoses (or something) bursts by either pumping up enough air pressure, or coolant thermal expansion when running engine. BTW, the cap is 21 psi on this engine so 23 is just a tad over.
310K mi
Re: Newbie with mysterious coolant loss [Re: Dodgevity] #2002646
01/31/16 01:55 PM
01/31/16 01:55 PM
Atlanta, GA, USA
Atlanta, GA, USA
More pics of the oil and coolant. I also tried a sizzle test. I dripped the oil onto a hot skillet and there was zero sizzle, so there is no water in the oil. Coolant, you can see for yourself.
310K mi
Page 2 of 3 1 2 3
