Ring choices? #2002620
01/31/16 01:22 PM
01/31/16 01:22 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I am freshening up a 541 ci RB for another racer and have run into a issue with the rings. This engine has 4.375" bore Mahle pistons (part # BBM350375F08) and "thin" (1.5,1.5,3.0mm) rings. The only mfg that I find with this size rings is Mahle. Anyone know if there are other choices available, or is Mahle the best/only way to go?
Thanks,
Brian
Re: Ring choices? [Re: '72CudaRacer] #2002866
01/31/16 08:05 PM
01/31/16 08:05 PM
My current E85 motor has the same ring pak on Diamond pistons, the rings came in a Total Seal box. I think mine where Moly top, cast second non Napier and low tension oil rings for the vacume pump. I would call Hastings and Total Seal to see what they both offer thumbs
