Which valve springs should I use?
#2000127
01/27/16 11:39 PM
01/27/16 11:39 PM
Posts: 64 Detroit
Got2Gnow
Detroit
Hey guys,
I have a 1971 Dodge Dart Swinger. It has a 318, LD4B intake manifold, 1406 600cfm carburetor, auto trans (factory stall convertor), 3.23:1 gears, P225-70R-14 rear tires, 2 1/4" dual exhaust (using factory exhaust manifolds), & MP electronic ignition. Everything else in/on the engine is factory (1971 vintage).
I will be adding the SummitRacing "SUM-K6900 - Summit Racing® Classic Cam and Lifter Kits" (Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 278/288, Lift .421/.444, Chrysler, Small Block).
The tech guy at SummitRacing said I should use "TFS-16901-16 - Trick Flow® by PAC Racing Single Valve Springs" (Valve Springs, PAC Racing, Single, 1.495 in. Outside Diameter, 355 lbs./in. Rate, 1.100 in. Coil Bind, Set 16)
But, I've heard/read other people say I should use "CCA-901-16 - COMP Cams Valve Springs" (Valve Springs, Single, 1.494 in. Outside Diameter, 353 lbs./in. Rate, 1.160 in. Coil Bind Height, Set of 16).
Which valve springs are correct? I'm a complete rookie with engine modifications (the electronic ignition almost put me over the edge).
Please help!!
Re: Which valve springs should I use?
[Re: Got2Gnow]
#2000164
01/28/16 12:15 AM
01/28/16 12:15 AM
RapidRobert
For a start I would measure your closed (base circle) and open (full lift) spring height dimentions and clearance between the coils at full lift "open" with what cam/springs are in there right now and the cam lift. the springs seem similar ex for installed height. How much are both sets? Yes I've seen that 901-16 recommendation many times from members who have went that route
[Re: Got2Gnow]
#2000193
01/28/16 12:46 AM
01/28/16 12:46 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I ran the same Comp #901's on a .470"/.470" cam and a .489"/.480" cam. They were good for my setup to about 6100/6200 rpms before valve float. Very good spring for both of my hydraulic flat tappet cams. I have been told they are good up to .490" lifts.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Got2Gnow]
#2000441
01/28/16 02:23 PM
01/28/16 02:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You are running what is basically the stock 340 cam, run the 340 valve springs too. Rock auto sells them for a bit less than the recommended kits above, SEALED POWER VS678, $3.30 each.
[Re: Supercuda]
#2000459
01/28/16 03:00 PM
01/28/16 03:00 PM
dogdays
The 340 springs mentioned above will work. They are safest choice. There is an Enginetech equivalent on Rockauto ERV901 which is even less expensive, like $2.01 each. I've had good luck with Enginetech parts.
You don't need Comp 901s or their equivalent. They are stiffer than you need and increase the risk of failure during breakin (although it is still quite small if you take care.)
R.
[Re: Got2Gnow]
#2001857
01/30/16 01:13 PM
01/30/16 01:13 PM
Supercuda
About to go away
About to go away
up yours
You almost NEVER need new retainers unless one of two things happens. Inspection shows the need for a replacement or you are building a very serious race motor with tons of spring pressure. You also do not need locks either, unless inspection shows the need to replace some. With the very mild, almost stock, cam you are looking to run you are fine with what you have unless you see something during installation that suggested you replace them. I would suggest you replace the valve stem seals while you are there though and since you should replace the valve cover gaskets (they will probably fall apart if they are old, cork ones) get the newer steel reinforced neoprene ones. Springs ENGINETECH ERV901 (already gave you the sealed power #) Valve stem seals FEL-PRO SS70014 (stock type, all seals incl.) Both at Rockauto.com As for the valve cover gaskets http://www.manciniracing.com/valcovgas.html
[Re: Got2Gnow]
#2003558
02/01/16 05:27 PM
02/01/16 05:27 PM
Supercuda
About to go away
About to go away
up yours
You are learning Grasshopper I totally forgot about rotators, never had any on my engines, but I only do pass car stuff for myself.
[Re: dogdays]
#2003615
02/01/16 06:46 PM
02/01/16 06:46 PM
RapidRobert
Supercuda, this is twice in a week I have agreed with you, must be a new record. For him or for you!
[Re: crackedback]
#2004127
02/02/16 02:46 PM
02/02/16 02:46 PM
dogdays
Once again I say unto you, that's nearly a stock cam, no need to go any better on springs than the Enginequest.
I'm sure many people have installed that cam or the 340 cam in a stock 318 or 360 and not changed the springs at all. Back in my chevy days I did the equivalent, swapped a .450 lift cam for a .400 lift cam without touching the springs. No issues except dealing with the extra power.
R.
