Rechrome Plastic Parts #2001889
01/30/16 01:46 PM
01/30/16 01:46 PM
Tennessee
WyleECoyote Offline OP
Tennessee
Where is the best quality place for getting parts rechromed (vacuum plating)?
I did a Google search for "rechrome plastic moparts" and found a post from 2010.
Members recommended back then:
1. Tony's Auto Classics in Texas
2. American Classics Restorations
3. CV Vacuum Platers
4. CV Plastics Plating in B.C.
I have a sunroof handle bezel I need restored for my 74 Charger; it has seen better days...
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2001976
01/30/16 03:55 PM
01/30/16 03:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The process most of those companies you listed will use is vacuumized aluminum which will then be covered in a clear coat, while nice in appearance, it's very delicate in nature, IIRC on the 73-4 B Body hand crank sunroof handle well it has a copper base under the nickel/chromium plating, the only place that I know of that can copper/nickel/chromium plate a plastic part the way the factory had done is Advance Plating in Nashville Tenn.
Family run business, top notch work, but expect to pay for that work, Steve can/will do mail ordered quotes/work/shipping on your parts
mike
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2001997
01/30/16 04:16 PM
01/30/16 04:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The biggest problem with that part is not plating it, but rather removing what's left of the old plating without ruining the plastic. Advanced might be able to remove it with a reverse chrome process, they'll be able to tell you.
Re: Rechrome Plastic Parts [Re: ScottSmith_Harms] #2002122
01/30/16 07:13 PM
01/30/16 07:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Rather than replate the well, maybe a NOS, or excellent used might do?
I haven't played with mopar sunroofs for a while, but these guys do
kelleys Sunroof Parts 888-298-8140, he's purchased all of ASC's vintage sunroof inventory, lots of stuff, decent prices
And Jim Burros 763-229-6888 won't be cheap though
Mike
Re: Rechrome Plastic Parts [Re: ScottSmith_Harms] #2002148
01/30/16 08:02 PM
01/30/16 08:02 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I've had good luck using the electrolysis rust removal set up to remove the old plating. I set up the system and use the plated plastic piece as the anode and the plating slowly goes away.....
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2002288
01/30/16 11:06 PM
01/30/16 11:06 PM
Tennessee
Tennessee
DAYCLONA Mike and others -
Thanks for the info and advice. I'll search out my options and report back with my results for others to learn from.
Thanks!
Ron
Wile E. Coyote
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2002760
01/31/16 04:54 PM
01/31/16 04:54 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
I believe CVV has been out of business for years..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Rechrome Plastic Parts [Re: 72N96RR] #2003273
02/01/16 11:27 AM
02/01/16 11:27 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Though CV Vacuum Platers still comes up on the internet I don't believe they are still in business unless they started back up. shruggy Here is a post from 2010 that talks about it:
http://www.dodgecharger.com/forum/index.php?topic=76173.0
I see a business in Mauston, WI called VP Vacuum Platers though. scope
http://www.vacuumplaters.com/
JB Rhinehart, Realist
A-Body's RULE!
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2003338
02/01/16 01:05 PM
02/01/16 01:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
As mentioned, removing the old stuff is the biggest problem. Most plastics aren't affected by mild acids so you could try soaking this (or a test piece) in something like metalprep or a Drano solution. Once the plating is gone one option would be someone that does "spray chrome". This is basically a paint process but you can't tell the difference once its done. Over the past few years guys doing this have sprung up all over the place.
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2003369
02/01/16 01:48 PM
02/01/16 01:48 PM
MA
steve70 Offline
steve70  Offline
MA
1970 Challenger T/A 4 speed
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2004588
02/03/16 02:04 AM
02/03/16 02:04 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Try Pauls. They have been advertising plastic plating for a while. There results on any type of metal is great, I would have to assume they put the same quality into plastic.
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2005933
02/05/16 03:25 AM
02/05/16 03:25 AM
Valencia, CA
K
kpkube Offline
kpkube  Offline
K
Valencia, CA
Re: Rechrome Plastic Parts [Re: kpkube] #2006006
02/05/16 11:15 AM
02/05/16 11:15 AM
6T4 Polara Offline
6T4 Polara  Offline
Has anyone tried this shop?
http://www.vacuumorna-metal.com/content/restoration
Yes had arm rests done and satisfied with results.
Re: Rechrome Plastic Parts [Re: 6T4 Polara] #2006734
02/06/16 02:11 PM
02/06/16 02:11 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Yes I have used vacuumorna-metal on interior dash bezels with great results, Frank is a stand up guy and delivered the parts when he said. Earlier I suggested Paul,s but I suggested that for exterior parts, I believe they plate exterior stuff triple plated just like metal.
Re: Rechrome Plastic Parts [Re: WyleECoyote] #2007725
02/08/16 01:32 AM
02/08/16 01:32 AM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
gcartrim.com
He does a good job on vacuum chrome. Used him several times now.
