Shifter id #2001182
01/29/16 02:44 PM
01/29/16 02:44 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Hello All, this was in the trunk of the 70' b body. Car is a factory four speed but I'm not sure this is the right shifter. 6356 is on the body and levers have 6353 and 6354 on them. Anyone know what this is for?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Shifter id [Re: busboy] #2001188
01/29/16 02:52 PM
01/29/16 02:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
68 69 Body with console .
Re: Shifter id [Re: busboy] #2001410
01/29/16 07:53 PM
01/29/16 07:53 PM
busboy Offline OP
busboy  Offline OP
Ok, thanks John. Far as I know the car was originally a bench car, I got a rolling shell and a bunch of boxes of parts so I'm just trying to figure this out. This was in the trunk. My plan is to rebuild it with buckets, can't find/afford a console anyway. Can I use the shifter if I change out the handle, I've always wanted a pistol grip?
Re: Shifter id [Re: busboy] #2001426
01/29/16 08:26 PM
01/29/16 08:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That shifter was not used in 1970 , 1970 was one year only on the handles and the shifter box. You can put a pistol grip shifter handle in that box but you'll be punching the dash in 1st , 3rd and reverse.
Sell it .
Re: Shifter id [Re: busboy] #2001447
01/29/16 09:02 PM
01/29/16 09:02 PM
busboy Offline OP
busboy  Offline OP
Thanks John, that's just what I needed to know, appreciate the help.
Re: Shifter id [Re: busboy] #2001560
01/29/16 11:31 PM
01/29/16 11:31 PM
busboy Offline OP
busboy  Offline OP
What shifter and linkage would be correct for what I'm doing?
Re: Shifter id [Re: busboy] #2001829
01/30/16 12:42 PM
01/30/16 12:42 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It's a little long in the explanation but if you put a pistol grip handle in that one, your hand will hit the dash in fist and third without bending the handle. The 70 shifter mechanism is different as well. I'll pm you later. I may have some extra parts and we could maybe make a trade that would help us both.
