Re: 440 build whats the best cam for street use [Re: Gerald l] #2000669
01/28/16 08:06 PM
01/28/16 08:06 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
One thing to consider is that trans, 23 spline? If the tires hook... Reason Chrysler put Danas & 18 splines behind the "stock" 440s even with the skinny tires of that time. I like the idea of a 440 crank in the 383 block -426 cubes or the 4.15 crank complete stroker kits. Ask thumper about his
Re: 440 build whats the best cam for street use [Re: Gerald l] #2000719
01/28/16 09:42 PM
01/28/16 09:42 PM
Washington
madscientist Offline
Washington
I have been 9.30's on a 23 spline box. You can't have the clutch beat the parts to death. The wrong clutch will destroy anything you put behind it.
Re: 440 build whats the best cam for street use [Re: Tommy D] #2001102
01/29/16 12:33 PM
01/29/16 12:33 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Originally Posted By Tommy D
Assuming your current engine makes around 300HP at the crank, switching from your current 3.23:1 gears to 3.91:1's would have a huge impact on "seat of the pants" feel.
It may impact "seat of the pants" feel, but it may not actually change et at track much...
I find that gear selection is not near as important with an even decent built 440. Further, the lighter the car, the less impact on et.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 build whats the best cam for street use [Re: Gerald l] #2001112
01/29/16 12:47 PM
01/29/16 12:47 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Leave the gears and transmission alone.
Forget the 440.
Order a stroker kit. Get a good streetable cam. Save the pocket change for the machine work.
When the money and parts are available, yank the 383 and get the bottom end done. Put it back together and enjoy the ride.
When the money is available for Eddy heads you can swap them out in an afternoon. The same goes for the intake and carb.
Playing with the low deck motor gives you more room to access the plugs and install headers and also keep the weight off the nose of the car.
- Stu Harmon
Re: 440 build whats the best cam for street use [Re: Gerald l] #2001134
01/29/16 01:45 PM
01/29/16 01:45 PM
GA
Gerald l Offline OP
Gerald l  Offline OP
GA
That's alot of options. I found a standard bore 440 block for $500 with the main caps and bolts.It has already been cleaned, shot peen'd and magnaflux' at the machine shop. I already have an Eddy rpm intake for a 440. I think I read somewhere that the heads from a 383/440 are interchangeable (temporary). Then I found a good deal on an eagle rotating assembly but it's only for a 446 for under 1500. Am I headed in the right direction piecing this bottom end together? I just don't know what size flat tappet cam to go with.
Re: 440 build whats the best cam for street use [Re: Gerald l] #2001270
01/29/16 04:21 PM
01/29/16 04:21 PM
AndyF Offline
AndyF  Offline
Sure, that will work. If you already have the rotating kit and heads and intake then you're on your way. Hard to go wrong with the Mopar Perf .528 solid flat tappet cam. It will have some lope at idle in a 446 but it won't be really rough. It will pull to 6000+ rpm once you put the Edelbrock (or Trick Flow) heads on there.
Re: 440 build whats the best cam for street use [Re: Gerald l] #2001295
01/29/16 04:45 PM
01/29/16 04:45 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you should be able to get a complete 440 for $500.00, next don't get the 446 rotating assembly unless you know the block with clean up at whatever oversize the pistons in the kit are.
yes you can use the 383 heads on the 440. good on the intake.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 440 build whats the best cam for street use [Re: feets] #2001314
01/29/16 05:21 PM
01/29/16 05:21 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Forget the 440.
Depending on what your budget is, I like the idea of stroking the 383, buying aluminum heads, water pump and intake. Lessens the weight on the nose a bit. You can build it with compression that will run on pump gas, choose a nice cam/carb combo and make plenty of HP for smoking the tires at the drop of hat. I think you will be totally thrilled. Those stroker motors are no slouch.
If you don't like that idea, plenty of 440 recommendations above. But, if you start hammering a stock 23 spline tranny and 8 3/4 with power launches, you will likely break something. If you don't hammer the crap out of it, then it will probably live and do just fine.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: 440 build whats the best cam for street use [Re: Gerald l] #2001411
01/29/16 07:56 PM
01/29/16 07:56 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Doesn't sound bad at all, assuming it's quality stuff.
The heads interchange from 350/361/383/413/426W/444. Valves and chamber sizes varied in the early to mid 60s but after that there's really no difference in performance.
- Stu Harmon
Re: 440 build whats the best cam for street use [Re: Gerald l] #2001649
01/30/16 01:21 AM
01/30/16 01:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
There are alot of smart people on here and many know alot about cams. But most of us are not pro's with cam selecting meaning we dont do it everyday like some pro's. Sure I can suggest a cam as I feel I know cams pretty good but myself I had a pro spec my last cam thats in my 63 Sport Fury. I wanted a cam to make good power and have a nice rump rump in the idle and Dwayne Porter speced me a cam that did that and he also made it keep my cyl pressure low enough to run fine on pump gas with the right valve timing specs. Dwayne is a pro and does cam selecting and specs everyday and he is very good at it. Many of us here are good with cams but most of us are not pro's as we dont do it for a living everyday like Dwayne Porter does. I would suggest you give Dwayne Porter a call (802-951-1955) and talk to him about your cam. It did not cost me any more going through him and I got a cam speced to my combo. I use a solid flat tappet and it works very good for my combo. It dont cost you anything to give him a call and talk to him. Ron
