Re: Wayne County speed shop
[Re: Airwoofer]
#2001354
01/29/16 06:22 PM
01/29/16 06:22 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Are they on a wayne county block , and are they t/s heads?
[Re: Airwoofer]
#2001694
01/30/16 01:57 AM
01/30/16 01:57 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Adger Smith told me that the B1 heads on my KOS Demon 499 were built by Wayne County. The car was first campaigned in 1996 by Hardesty. The nefarious break in at the shop, vandalism of the motors, and subsequent demise of the Dodge Boys was in 1995. Does anyone know if Wayne County was still doing heads after that break-in? I wonder if the heads I have were one of those sets that they were running or if they still were doing heads after the break-in.
Darn things have been milled to 47cc which makes it hard to convert to a street motor on a Vortech. I doubt they are anything special........just some heavily milled B-1s. And just because Hardesty ran the Demon in 96, doesn't mean he didn't have the motor well before. He had the RR before the Demon
[Re: TRENDZ]
#2001897
01/30/16 02:01 PM
01/30/16 02:01 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Are they on a wayne county block , and are they t/s heads? Low deck KB block. The thing was just under 500 CI with a 3.85 bryant crank. I do not know what makes a TS head but these have Ti 2.44 IN and 1.88 EX valves.
[Re: Airwoofer]
#2001919
01/30/16 02:40 PM
01/30/16 02:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are they on a wayne county block , and are they t/s heads? Low deck KB block. The thing was just under 500 CI with a 3.85 bryant crank. I do not know what makes a TS head but these have Ti 2.44 IN and 1.88 EX valves. Sounds like they are the M/C heads with a larger valve... the M/C came with a 2.4 intake.. yeah your gonna have to buzz that engine to make use of the heads
[Re: Airwoofer]
#2002024
01/30/16 04:52 PM
01/30/16 04:52 PM
TRENDZ
Milwaukee WI
Are they on a wayne county block , and are they t/s heads? Low deck KB block. The thing was just under 500 CI with a 3.85 bryant crank. I do not know what makes a TS head but these have Ti 2.44 IN and 1.88 EX valves. The engines they were running had heads and blocks that were not compatible with any mopar block. If they bolt on to a KB block, they were not in those PS cars of the period. That's not to say they didn't come from wayne cty, just that they weren't in the PS cars. The B1 ts head is a canted valve head. The heads they used on the PS cars were...."bigger"
[Re: TRENDZ]
#2002226
01/30/16 09:30 PM
01/30/16 09:30 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Are they on a wayne county block , and are they t/s heads? Low deck KB block. The thing was just under 500 CI with a 3.85 bryant crank. I do not know what makes a TS head but these have Ti 2.44 IN and 1.88 EX valves. The engines they were running had heads and blocks that were not compatible with any mopar block. If they bolt on to a KB block, they were not in those PS cars of the period. That's not to say they didn't come from wayne cty, just that they weren't in the PS cars. The B1 ts head is a canted valve head. The heads they used on the PS cars were...."bigger" So, if they weren't mopar blocks, what were they?
[Re: Airwoofer]
#2002236
01/30/16 09:47 PM
01/30/16 09:47 PM
TRENDZ
Milwaukee WI
Wayne County Blocks. Wider bore spacing. I never had my hands on one. I tried ordering t/s p/s heads, and was informed by the parts depot that they were special ordered, and fit wayne county blocks exclusively. I have no idea who made these blocks, or if they were just a wide bore spaced chevy block with different bolt pattern. I tried ordering them in maybe 1994 or 5. They were listed in the MP catalog, but I don't think the blocks were. I'm pretty sure the early B1TS head bolted directly to hemi blocks, used the drains and needed the hemi pushrod clearance. They were symetrical port canted valve heads.
[Re: Airwoofer]
#2002391
01/31/16 12:42 AM
01/31/16 12:42 AM
Monte_Smith
North Alabama
I have a set of 4.840 bore space TS heads with the "Wayne County" pattern, which is essentially a HEMI head bolt pattern, spread to fit the 4.840 bore space.
They used GM "style" blocks in those years..........I think.
Airwoofers heads are just standard B-1s. May be MCs, but I don't think so, but he says they have 2.44 intakes.....so could be
[Re: Dodgeguy101]
#2002652
01/31/16 02:09 PM
01/31/16 02:09 PM
TRENDZ
Milwaukee WI
this is a pic of a t/s head engine. Found this pic in a search on here.
[Re: Airwoofer]
#2002812
01/31/16 06:18 PM
01/31/16 06:18 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
the block of the motor in the pic looks to have Chevy style motor mount bosses.
[Re: Al_Alguire]
#2003739
02/01/16 09:48 PM
02/01/16 09:48 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
In 96 Hardesty was using Transact power and Indy heads. Later he went to Adjer.
