Re: Carb? 408 to 434
[Re: justinp61]
#2000010
01/27/16 09:06 PM
01/27/16 09:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its gonna depend on the rpm on the peak HP.. for the time jet up a couple then check the A/F ratio on the dyno
[Re: AndyF]
#2000085
01/27/16 10:47 PM
01/27/16 10:47 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
You don't need to change the jets just because it is going on a bigger engine. The carb self adjusts. More airflow pulls harder on the jet and pulls in more fuel.
You only need to change the jets if the weather changes or the altitude. You can jet up to be safe but if the carb was correctly calibrated before then it should be fine now. ^^^This!^^^
[Re: justinp61]
#2000153
01/28/16 12:04 AM
01/28/16 12:04 AM
Thumperdart
State of confusion
If it was good on the other motor I`d run it and watch the afr`s, read the plugs and go from there.......
[Re: justinp61]
#2000758
01/28/16 10:47 PM
01/28/16 10:47 PM
Posts: 304 Florida
Mark Whitener
I wouldn't go up at all. 2 jet sizes is a bunch. Jet up one at a time art the track to see if it improves, down if the first hurts it.
Mark Whitener [url=www.racingfuelsystems.com[/url]
