Carb? 408 to 434 #1999996
01/27/16 08:52 PM
01/27/16 08:52 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Since my 434 is almost done I'm trying to work off the short list to get it ready for the dyno. I have a Bigs 950HP that was tuned for the 408. It's been sitting for almost a year so I'm taking it apart giving a good cleaning and installing new gaskets. How much should I jet it up for the initial pull?
Re: Carb? 408 to 434 [Re: justinp61] #2000003
01/27/16 09:02 PM
01/27/16 09:02 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
It probably has something like 74/83 in it. I would either leave it alone or maybe just put 2 more in it front rear. Dyno operator will know right off if its lean.
Re: Carb? 408 to 434 [Re: justinp61] #2000010
01/27/16 09:06 PM
01/27/16 09:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its gonna depend on the rpm on the peak HP.. for
the time jet up a couple then check the A/F ratio
on the dyno
wave
Re: Carb? 408 to 434 [Re: justinp61] #2000079
01/27/16 10:41 PM
01/27/16 10:41 PM
AndyF Offline
AndyF  Offline
You don't need to change the jets just because it is going on a bigger engine. The carb self adjusts. More airflow pulls harder on the jet and pulls in more fuel.
You only need to change the jets if the weather changes or the altitude. You can jet up to be safe but if the carb was correctly calibrated before then it should be fine now.
Re: Carb? 408 to 434 [Re: AndyF] #2000085
01/27/16 10:47 PM
01/27/16 10:47 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
^^^This!^^^
Re: Carb? 408 to 434 [Re: justinp61] #2000153
01/28/16 12:04 AM
01/28/16 12:04 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If it was good on the other motor I`d run it and watch the afr`s, read the plugs and go from there.......
Re: Carb? 408 to 434 [Re: justinp61] #2000718
01/28/16 09:41 PM
01/28/16 09:41 PM
W. Kentucky
W. Kentucky
Thanks guys, I'll jet up two on both ends for just good measure.
Re: Carb? 408 to 434 [Re: justinp61] #2000758
01/28/16 10:47 PM
01/28/16 10:47 PM
Mark Whitener Offline
I wouldn't go up at all. 2 jet sizes is a bunch. Jet up one at a time art the track to see if it improves, down if the first hurts it.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Carb? 408 to 434 [Re: justinp61] #2000837
01/29/16 12:35 AM
01/29/16 12:35 AM
W. Kentucky
W. Kentucky
Thanks, I'll start with the current set up and see how it looks.
