Re: Happy on 93-octane Pump Gas?
[Re: AndyF]
#2000657
01/28/16 06:54 PM
01/28/16 06:54 PM
Posts: 1,032 ohio
67mprfan
ohio
You're at about the compression as me and I have ran pump gas with no problems
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: AndyF]
#2000672
01/28/16 07:10 PM
01/28/16 07:10 PM
Posts: 3,250 Between a rock & a hard place
cudadoug
Maybe! If it was mine I'd buy a few cans of Hot Rod 102 and start off with a 50/50 mix and then work my way down from there. Keeping things cool helps a lot so it might depend on the weather too. What Mr. F says. But I'd bet that with that quench, the aluminum heads and the cranking pressure it will be all good.
[Re: BradH]
#2000703
01/28/16 08:15 PM
01/28/16 08:15 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My small block with Indy-2 heads, 10.9 compression and 255/266 @ .050 cam has never ran on anything but 93 octane. Cranking cylinder pressure ranged last time checked from 195-201 lbs.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: BradH]
#2000776
01/28/16 10:13 PM
01/28/16 10:13 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
With that converter you will be golden.
Mopar to the bone!!!
[Re: 72Swinger]
#2000842
01/28/16 11:43 PM
01/28/16 11:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With that converter you will be golden. I agree... with the stat and the conv you shouldnt have any issue.. I run a W-2 head with 10.6 and on the road I run 87 octane and even get on it a fair bit...at 900' to 1000' local but in semi light car with a 5000 conv and a 4.10 gear.. I dont think you have any issues
[Re: BradH]
#2000949
01/29/16 01:44 AM
01/29/16 01:44 AM
Posts: 43,909 Bend,OR USA
Cab_Burge
These are iron heads, correct? If not they fooled me If so good luck on using any pump gas less than 100 octane with that much compression in your area If aluminum heads you may get away with that compression and pump gas without ethanol, maybe not on a hot day
[Re: BradH]
#2001090
01/29/16 11:14 AM
01/29/16 11:14 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I cant see any reason why it wouldn't be fine on 93?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
