Re: are 71 b-body danas rare
[Re: second 70]
#2000469
01/28/16 03:14 PM
01/28/16 03:14 PM
Posts: 5,268 NY
70440+6bbl
NY
They are fairly hard to find, but do pop up regularly. The correct e-body Dana is more desirable though.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: second 70]
#2001196
01/29/16 03:03 PM
01/29/16 03:03 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I was working on my 70 cuda the other day and found the codes on my danas axle tubes. It is 9-15-OA1 9-15-70 B7 603222-1 which makes it a lynch rd. b-body 3:54? The perches must have been moved because these are longer than an e-body. I just didn't know how rare these danas are? What makes you think it's a Lynch Rd. rear end ?
[Re: second 70]
#2001198
01/29/16 03:05 PM
01/29/16 03:05 PM
JohnRR
U.S.S.A.
I was getting ready to change it to a 4:10 and since my car is non-numbers matching I thought I would check to see how rare they are before I did incase someone with a #s matching car really needed it. It's going to cost you more to replace the rear with an E body rear, or get a rear from a place like strange, because the perches have been moved so it's going to sell for less than one that has not been dicked with. It's set up in your car, change the gears .
[Re: JohnRR]
#2001547
01/29/16 11:07 PM
01/29/16 11:07 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I was getting ready to change it to a 4:10 and since my car is non-numbers matching I thought I would check to see how rare they are before I did incase someone with a #s matching car really needed it. It's going to cost you more to replace the rear with an E body rear, or get a rear from a place like strange, because the perches have been moved so it's going to sell for less than one that has not been dicked with. It's set up in your car, change the gears . I would agree. Just use it or offer it up as trade bait.
[Re: second 70]
#2004266
02/02/16 05:57 PM
02/02/16 05:57 PM
Posts: 103 muskegon MI
v cummins
muskegon MI
In the date is says it was 9-15-0 A1 A is lynch road. 9-15-70 B7 just thought the A meant lynch. Not really sure. Its what shift that operation took place
[Re: v cummins]
#2004321
02/02/16 07:20 PM
02/02/16 07:20 PM
Posts: 1,707 central il.
second 70
central il.
In the date is says it was 9-15-0 A1 A is lynch road. 9-15-70 B7 just thought the A meant lynch. Not really sure. Its what shift that operation took place So does that mean A-lynch Rd. 1- 1st shift then what does the B7 mean?
[Re: second 70]
#2004367
02/02/16 08:41 PM
02/02/16 08:41 PM
v cummins
muskegon MI
In the date is says it was 9-15-0 A1 A is lynch road. 9-15-70 B7 just thought the A meant lynch. Not really sure. Its what shift that operation took place So does that mean A-lynch Rd. 1- 1st shift then what does the B7 mean? A is first shift. 1 is line 1 B is second shift. 7 is line 7 If A was lynch Rd., that means the B meant that they changed their mind and went to Hamtramck.
