1994 Ram 1500 wheel hub question.
#2000247
01/28/16 02:00 AM
01/28/16 02:00 AM
Posts: 2,529 God's Country Maryland
GODSCOUNTRY340
My '94 1500 4x4 has both front hubs worn out. It's an SLT with 4 wheel ABS and I'm having a hard time finding ABS hubs for it. There are non ABS hubs readily available. My question is, will the non ABS hubs bolt in place of the ABD hubs. I realize I won't have ABS in the front anymore but will I get a pulsating brake pedal, if they'll swap?
Re: 1994 Ram 1500 wheel hub question.
[Re: GODSCOUNTRY340]
#2000300
01/28/16 08:22 AM
01/28/16 08:22 AM
Posts: 5,917 ohio
ruderunner
ohio
Yes they should bolt up. No more and at all though and the right will stay on. But bearing don't cause a pulsing pedal, warped or rusted rotors do.
Angry white pureblood male
#2003190
02/01/16 02:26 AM
02/01/16 02:26 AM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
My '94 1500 4x4 has both front hubs worn out. It's an SLT with 4 wheel ABS and I'm having a hard time finding ABS hubs for it. There are non ABS hubs readily available. My question is, will the non ABS hubs bolt in place of the ABD hubs. I realize I won't have ABS in the front anymore but will I get a pulsating brake pedal, if they'll swap? The wheel bearings are the same with or without ABS. The axle has the tone ring/counter wheel.
