Is it absolutely necessary to tube them... no.. but
it helps if you lose a lifter and you dump all the
oil pressure... on my LA block (416 in my Rampage)
I bushed them with a .060 hole in the bushings and
a .040 restriction in the PRs.. this is with a solid
roller with .640 lift at the valve.. it was within
.015 of uncovering the oil passage so I left the bushings
on the tall side just to make sure it didnt have a issue..
I'm running the EDM hole in the lifter for the street which
is .026 for that hole.. with all the little leaks you will
show lower oil pressure.. also this is with TD rockers...
all in all its a easier way to control oil losses
