8 3/4 CENTER-SECTION WEIGHT
#1999271
01/26/16 08:46 PM
01/26/16 08:46 PM
Thumperdart
State of confusion
Anyone have the weight of one w/caps by chance? Thankxx.......
Re: 8 3/4 HOUSING WEIGHT
[Re: Thumperdart]
#1999333
01/26/16 10:13 PM
01/26/16 10:13 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I just pulled my 742 apart to replace the spiders in the PowrLok. I can get you a weight in the next couple days.
Mopar to the bone!!!
[Re: mkdart]
#1999334
01/26/16 10:14 PM
01/26/16 10:14 PM
Thumperdart
State of confusion
Thankxxx........Was lookin at the nodular Dr Diff unit and it`s around 36 lbs. and way beefier in the right places............
[Re: 72Swinger]
#1999351
01/26/16 10:36 PM
01/26/16 10:36 PM
Thumperdart
State of confusion
I just pulled my 742 apart to replace the spiders in the PowrLok. I can get you a weight in the next couple days. Sure, that`s what I have now except w/a 30 spline spool.......
[Re: Thumperdart]
#1999391
01/26/16 11:14 PM
01/26/16 11:14 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
I went out and weighed my empty 742 case for ya - 30 lbs even. That was with caps, cap bolts, adjusters, two bearing races still installed, the drain plug and two pinion snubber bolts still in the housing.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#1999403
01/26/16 11:20 PM
01/26/16 11:20 PM
Thumperdart
State of confusion
Thankxxx man. Did some research today on nodular iron vs factory cast iron and the nodular seems way stronger and Dr. Diff agrees and for $300 bucks w/billet caps and adjusters, I can`t go wrong and don`t want a truck or ford rear under my car. Mine has lasted longer than most into the 9`s at 3200+ lbs w/30 spline axles so this along w/35 spline axles, a new spool and around 3000 lbs.(for now), I should be golden...........
[Re: Thumperdart]
#1999431
01/26/16 11:41 PM
01/26/16 11:41 PM
RMCHRGR
Spahn Ranch
Sounds like a good deal. Certainly more cost effective than an aluminum case and leaves more in the budget for better parts. Cass is the man.
[Re: RMCHRGR]
#1999443
01/26/16 11:54 PM
01/26/16 11:54 PM
Thumperdart
State of confusion
Was looking at the Alum. case but can`t justify the cost and can damn near have a complete 3rd member for the cost of the alum. case alone plus I may sell the car anyhow...........
[Re: Thumperdart]
#1999506
01/27/16 12:47 AM
01/27/16 12:47 AM
RMCHRGR
Spahn Ranch
Was looking at the Alum. case but can`t justify the cost and can damn near have a complete 3rd member for the cost of the alum. case alone plus I may sell the car anyhow........... You're right, it is hard to justify the cost on them now. Not sure who their market is either, no one in their right mind would pay that much for just a case, even if it weighs XX amount less. I got mine when they first came out about 10-12 years ago? I think it was like $600. How much does the one from Cass weigh?
[Re: RMCHRGR]
#1999541
01/27/16 01:38 AM
01/27/16 01:38 AM
Thumperdart
State of confusion
Too funny on the Quicktree deal....... Cass`s weights just under 36 lbs. he said and uses the same billet caps as the 9"......
[Re: Charger453]
#1999553
01/27/16 01:55 AM
01/27/16 01:55 AM
Thumperdart
State of confusion
Good to know thankxxx...........
