Page 1 of 6 1 2 3 4 5 6
8 3/4 CENTER-SECTION WEIGHT #1999271
01/26/16 08:46 PM
01/26/16 08:46 PM
State of confusion
Thumperdart Offline OP
State of confusion
Anyone have the weight of one w/caps by chance? Thankxx.......
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999280
01/26/16 09:03 PM
01/26/16 09:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
There are a few different thickness housings. That's why some last longer then others. Or are you talking about the center section?
Re: 8 3/4 HOUSING WEIGHT [Re: FastmOp] #1999292
01/26/16 09:17 PM
01/26/16 09:17 PM
State of confusion
State of confusion
Yes, my bad Center section............. realcrazy
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999331
01/26/16 10:09 PM
01/26/16 10:09 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
489 w/caps only 27lbs
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999333
01/26/16 10:13 PM
01/26/16 10:13 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I just pulled my 742 apart to replace the spiders in the PowrLok. I can get you a weight in the next couple days.
Mopar to the bone!!!
Re: 8 3/4 HOUSING WEIGHT [Re: mkdart] #1999334
01/26/16 10:14 PM
01/26/16 10:14 PM
State of confusion
State of confusion
Thankxxx........Was lookin at the nodular Dr Diff unit and it`s around 36 lbs. and way beefier in the right places............
Re: 8 3/4 HOUSING WEIGHT [Re: 72Swinger] #1999351
01/26/16 10:36 PM
01/26/16 10:36 PM
State of confusion
State of confusion
Sure, that`s what I have now except w/a 30 spline spool.......
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999391
01/26/16 11:14 PM
01/26/16 11:14 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I went out and weighed my empty 742 case for ya - 30 lbs even. That was with caps, cap bolts, adjusters, two bearing races still installed, the drain plug and two pinion snubber bolts still in the housing.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: 8 3/4 HOUSING WEIGHT [Re: RMCHRGR] #1999403
01/26/16 11:20 PM
01/26/16 11:20 PM
State of confusion
State of confusion
Thankxxx man. Did some research today on nodular iron vs factory cast iron and the nodular seems way stronger and Dr. Diff agrees and for $300 bucks w/billet caps and adjusters, I can`t go wrong and don`t want a truck or ford rear under my car. Mine has lasted longer than most into the 9`s at 3200+ lbs w/30 spline axles so this along w/35 spline axles, a new spool and around 3000 lbs.(for now), I should be golden...........
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999431
01/26/16 11:41 PM
01/26/16 11:41 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Sounds like a good deal. Certainly more cost effective than an aluminum case and leaves more in the budget for better parts. Cass is the man.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: 8 3/4 HOUSING WEIGHT [Re: RMCHRGR] #1999443
01/26/16 11:54 PM
01/26/16 11:54 PM
State of confusion
State of confusion
Was looking at the Alum. case but can`t justify the cost and can damn near have a complete 3rd member for the cost of the alum. case alone plus I may sell the car anyhow...........
Re: 8 3/4 CENTER-SECTION WEIGHT [Re: Thumperdart] #1999444
01/26/16 11:57 PM
01/26/16 11:57 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I thought maybe you needed shipping weight to send one to Quicktree. boogie
Re: 8 3/4 CENTER-SECTION WEIGHT [Re: slantzilla] #1999461
01/27/16 12:09 AM
01/27/16 12:09 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
eek
haha
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999506
01/27/16 12:47 AM
01/27/16 12:47 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
You're right, it is hard to justify the cost on them now. Not sure who their market is either, no one in their right mind would pay that much for just a case, even if it weighs XX amount less. I got mine when they first came out about 10-12 years ago? I think it was like $600.
How much does the one from Cass weigh?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: 8 3/4 HOUSING WEIGHT [Re: RMCHRGR] #1999541
01/27/16 01:38 AM
01/27/16 01:38 AM
State of confusion
State of confusion
Too funny on the Quicktree deal....... laugh2 Cass`s weights just under 36 lbs. he said and uses the same billet caps as the 9"......
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999544
01/27/16 01:42 AM
01/27/16 01:42 AM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
I bought one of those housings from Cass last year. They're definitely beefier and a worthwhile upgrade for the price. I can't attest to how much abuse it can handle as I only have 2 passes on it.
Re: 8 3/4 HOUSING WEIGHT [Re: Charger453] #1999553
01/27/16 01:55 AM
01/27/16 01:55 AM
State of confusion
State of confusion
Good to know thankxxx...........
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999589
01/27/16 03:32 AM
01/27/16 03:32 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Funny how Yukon advertises them "up to 500 hp"...
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999610
01/27/16 05:33 AM
01/27/16 05:33 AM
All three of the stock Mopar 8 3/4 center section are cast steel, not cast grey iron runaway Put a steel billet cap on the drivers side and go have fun up twocents
Re: 8 3/4 HOUSING WEIGHT [Re: Thumperdart] #1999620
01/27/16 08:47 AM
01/27/16 08:47 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
work ....Don't tell me your going pro-mod too......LOl J/K grin
