Cuda Trunk Lock Gasket Question #1956118
11/22/15 10:04 PM
11/22/15 10:04 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
I just installed a new trunk lock gasket from Detroit Muscle Technologies. (See pic below).
How does the look of this gasket compare to originals…sizing and color? Does anyone have a picture of an unrestored car with the original gasket installed? I’d like to compare.
Thanks everyone!
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #1956449
11/23/15 02:17 PM
11/23/15 02:17 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
DMT's gaskets are sized and made based on NOS originals. I would think that the one on your car should be spot on compared to the original.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #1956454
11/23/15 02:26 PM
11/23/15 02:26 PM
Indianapolis, IN
Indianapolis, IN
Thanks, Dwight. That's what I was wondering.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #1999191
01/26/16 07:20 PM
01/26/16 07:20 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Looks SPECTACTULAR smile
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #1999299
01/26/16 09:29 PM
01/26/16 09:29 PM
Indianapolis, IN
Indianapolis, IN
I agree! You have fantastic products.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #1999338
01/26/16 10:23 PM
01/26/16 10:23 PM
WA
tman Offline
tman  Offline
WA
I like!
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2002876
01/31/16 08:18 PM
01/31/16 08:18 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
is different than a b c and e body challenger ,body door and trunk lock gaskets?
5549 post on old board
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2002963
01/31/16 10:22 PM
01/31/16 10:22 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2067447
05/04/16 10:00 PM
05/04/16 10:00 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
This an example of the unrestored original from the Tabbaco heir Hemi Cuda.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2067452
05/04/16 10:07 PM
05/04/16 10:07 PM
Indianapolis, IN
Indianapolis, IN
Thanks ucudant. I saw that picture after my initial posting and compared it to the one I installed on my car.
It looks like the original gasket on the Tobacco car doesn't protrude out as far from the stainless lock bezel compared to the DMT gaskets. However, the gasket on this car is 45 years old, so it has probably shrunk or been modified in some way by the environment. It doesn’t even have the grey coloring anymore.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2067982
05/05/16 09:45 PM
05/05/16 09:45 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2069336
05/08/16 01:45 PM
05/08/16 01:45 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
I found a old shot of mine, new gasket installed.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2133185
08/15/16 01:19 AM
08/15/16 01:19 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I know this is an old post but I also have black versions of those gaskets. Even Mopar replacements came in gray and black. Black would probably look better on that tailpanel.
In fact I make all of my gaskets in black for some customers doing black or dark colored card.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2133339
08/15/16 10:09 AM
08/15/16 10:09 AM
Indianapolis, IN
Indianapolis, IN
Good to know.
Actually, It's funny you should mention this because I was at the Nationals this past weekend and I saw a 70 AAR with a black gasket behind the trunk lock. It looked like it had been there for quite some time. I could not tell if it was assembly line issue. I should have taken a picture...
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2326100
06/24/17 01:49 PM
06/24/17 01:49 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I know an old post but curious if anyone can confirm color used, grey or black?
Is it possible that this was changed at some point by year?
Or based on body color?
Mine being a mid March 70 build AAR, any idea what would be correct?
I'll keep digging in old parts and post what I find . . . If I find it
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2327431
06/27/17 10:43 AM
06/27/17 10:43 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Thought I would share my findings since no-one jumped in . . .
Couldn't locate my original, vaigly recall it being split in several places and in my haste tossing it.
Called several friends with AAR's, some restoring previously unrestored cars, a couple refinished (by the current owner), and a few survivors, all reported the same findings, black. So it would appear that at least for AAR's, black was used.
Now the question becomes were the black seals used;
Only on AAR's (doubtful)?
Only on blackout tail panels?
Only on blackout tail panels for some period?
Only up to a date?
Only between some dates?
Or randomly based on supplier?
Logically (so this can't be since its Chrysler), cars with an Argent tail panel would get grey and cars with blackout would get black. As seen on the Reynolds 71 Cuda, this doesn't appear to hold true.
Re: Cuda Trunk Lock Gasket Question [Re: B5Cuda440-6] #2327443
06/27/17 11:12 AM
06/27/17 11:12 AM
Indianapolis, IN
Indianapolis, IN
AAR#2 - I have several pictures of unrestored/survivor 70 Hemi Cuda's and they all have the grey gasket as made by DMT. The build dates on the Hemi cars I’ve documented almost span the entire model year of production, but that doesn’t mean a black gasket was not used. I’ve only seen a couple survivor AARs, and I don’t recall seeing a black gasket on the car. I would think that detail would have jumped out at me.
One item to keep in mind is that back then you could buy and change the locks, if needed. Could it be that the Mopar replacement lock packages contained a black gasket, vs. the assembly line grey gaskets? Not sure.
On another note, I have since been told that the factory grey trunk lock gaskets are more “spongy” than the DMT gasket, which makes it easier to install the retaining clip inside the trunk. I have not been able to confirm this by seeing an original gasket in person, however.
