Page 4 of 4 1 2 3 4
Re: 440 stock stroke 10 second combos [Re: Project kickin A] #2002514
01/31/16 05:08 AM
01/31/16 05:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By Project kickin A
it had whats called an Aeroflow black 140 equivalent to a holley black. all -8 lines from cell to carb. I knew it wasn't going to cut it but up until then it had been running quicker and quicker, guess I found its limit.
Thats interesting as I run the Holley black pump with 3/8 fuel line and use an 850 DP. it has run 10.70's at almost 125. It also ran the same 10.70's at almost 125 with just the Holley red pump before I switched to the black pup. Ron
Re: 440 stock stroke 10 second combos [Re: 383man] #2002517
01/31/16 05:29 AM
01/31/16 05:29 AM
Australia
P
Project kickin A Offline
P
Australia
Thats interesting
It is but that 140 is rated unregulated so I found out. more like 100 at 7 psi. I also had it plumbed to a deadhead so.... it could have been ok with a return.
Re: 440 stock stroke 10 second combos [Re: Project kickin A] #2002548
01/31/16 11:08 AM
01/31/16 11:08 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Thats interesting
also what fuel filter are you using can regulate the fuel pump too
1.39 9.85 - 137 mph
Re: 440 stock stroke 10 second combos [Re: Street Monkies] #2581955
11/23/18 03:55 PM
11/23/18 03:55 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I've had nothing but bad experience with the Team G, the old Mopar M1 was worth 80 hp over the team G......I've still got the team G after 25 years because I cant sell it with a clear conscious, it's that bad. Get a deferant intake.
Have a great day
Iowan
"obsolete is neat"
Re: 440 stock stroke 10 second combos [Re: Street Monkies] #2582306
11/24/18 12:26 PM
11/24/18 12:26 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
73 Dart Sport, 440, stoke stroke,.030 speed pro flat top,lay rods,mopar.557,Indy Srs, team g, 750 alcohol carb,4800 Lupo,Dana 4.56,31x10.5w. 6.60s @ 103 in 1/8. 10:50s running out of motor. Switched from Indy 440-3 to team g . No et change.
Re: 440 stock stroke 10 second combos [Re: qwkmopardan] #2582527
11/24/18 07:53 PM
11/24/18 07:53 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Originally Posted By qwkmopardan
This was a build for a buddys 1968 Satelite
.055 over 1966 440 block
NOS cast crank--3.75 stroke--internal balance--no Mallory metal
Eagle 6.76 rods for .990 pins
JE Flat top piston--.025 in the hole--CR 10.5 to 1--Runs on 93 oct pump gas
Racer Brown Solid lifter flat tappet cam--STX-21--272*/272*-.560"/.560"
Edelbrock Performer RPM heads with a decent port job and a Red CC inner spring added--shaved .040
Victor Intake w 1000CFM Carb Shop Carb-4150
Hooker competition headers--1 7/8" primary tubes
Dynamic 9 1/2" TQ Converter
Dana 60 W/Spool and 4.10 Gear set
3600# SS Springs w/ no snubber or anything else
29x 10.5" MT stiff side wall slicks
drivers seat--heater delete full C/M cage-- aprox 3500# w driver
10.29 at 129.xx MPH--1.39 60ft
Am I missing something here?
Re: 440 stock stroke 10 second combos [Re: Street Monkies] #2582643
11/24/18 11:38 PM
11/24/18 11:38 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Dan is well known for doing more with less. He is a firm believer in Racer Brown cams. His own cars run extremely well for what they are too.
Getting old just means you were smarter than some and luckier than others.
Re: 440 stock stroke 10 second combos [Re: Street Monkies] #2582655
11/25/18 12:46 AM
11/25/18 12:46 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By Street Monkies
For the guys running LY rods, or a cheap I beam/H beam rod. Was is your thoughts on those?. I found some I beam rods on ebay and the company claims they will handle 800 hp. Has ARP bolts. They weigh 800g, and they're $255. They're cheap H beam rods but most of them have the .990 pin.
We have a .030 440 with cast crank,LY rods, 7 TRW pistons, 1 Manley piston that I shaped myself with a grinder, SR heads. Has been 9.64 @ 135 on the bottle and 15 years on it's now in my sons Aussie A body Valiant street car and runs 11.1 121 naturally aspirated, cheap thrills.
1963 Plymouth Max Wedge
1971 Barracuda
Re: 440 stock stroke 10 second combos [Re: Iowan] #2582672
11/25/18 02:26 AM
11/25/18 02:26 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
WOW, ALMOST A 3 YEAR bump Still some really good info, thanks thumbs
Re: 440 stock stroke 10 second combos [Re: dannysbee] #2582714
11/25/18 05:33 AM
11/25/18 05:33 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I saw the post from the Lebaron too. Its a little too light for me to relate to, but if that B body was .5 second and 5 mph slower I would still think it ran pretty well for what it is. That's almost 130 MPH for a stock stroke 440, with standard port heads, that is pretty darn impressive.
Dan, who did the head work?
Page 4 of 4 1 2 3 4
