Re: 440 stock stroke 10 second combos
[Re: Street Monkies]
#2001259
01/29/16 04:12 PM
01/29/16 04:12 PM
Posts: 1,030 ohio
67mprfan
ohio
I am thinking maybe trying a freak show converter, and having them decide the stall I need. Does anyone think a 4500 1050 is too big? The carburetor calculator says I need around a 950. That's what I'm using now.the calculator showed me needing a 1000 cfm Carb the second choice was a 1050
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
#2001501
01/29/16 10:17 PM
01/29/16 10:17 PM
Posts: 5,618 long island NY
Ari440
long island NY
has any one have results with a 446-452ci with INDY 440-1s or B1 heads
im putting together a 446ci B1 combo
1.39 9.85 - 137 mph
#2001762
01/30/16 05:24 AM
01/30/16 05:24 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
This was a build for a buddys 1968 Satelite .055 over 1966 440 block NOS cast crank--3.75 stroke--internal balance--no Mallory metal Eagle 6.76 rods for .990 pins JE Flat top piston--.025 in the hole--CR 10.5 to 1--Runs on 93 oct pump gas Racer Brown Solid lifter flat tappet cam--STX-21--272*/272*-.560"/.560" Edelbrock Performer RPM heads with a decent port job and a Red CC inner spring added--shaved .040 Victor Intake w 1000CFM Carb Shop Carb-4150 Hooker competition headers--1 7/8" primary tubes Dynamic 9 1/2" TQ Converter Dana 60 W/Spool and 4.10 Gear set 3600# SS Springs w/ no snubber or anything else 29x 10.5" MT stiff side wall slicks drivers seat--heater delete full C/M cage-- aprox 3500# w driver 10.29 at 129.xx MPH--1.39 60ft
#2001764
01/30/16 05:40 AM
01/30/16 05:40 AM
qwkmopardan
Affton MO
My Car 89 Chrysler LeBaron 383 block w modified production 440 steel crank--3.900 stroke 449c.i. 11 to 1 CR--Zero Decked flat tops ported 915 heads Victor 383 intake Racer Brown solid flat tappet cam. .560/.560--272*/272* 727 trans w/8" Dynamic converter 9" rear w 4.10 gear set 15x33 tires 2500# w driver 9.02 at 149 mph--1.21 60ft
#2001893
01/30/16 01:56 PM
01/30/16 01:56 PM
Posts: 5,160 Texas
dannysbee
Texas
Brad I believe the shift point on the 446 b1 l have was 7800. It pushed 3800 lbs of car 138 mph. The piston speed would be less than a 4.5 stroker turning 6800.
Getting old just means you were smarter than some and luckier than others.
[Re: Ari440]
#2001912
01/30/16 02:30 PM
01/30/16 02:30 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Supposedly the team G 4500 tall top is better then the 4150 version. The 4150 version has the dents in the runners and they need a lot of work, and even the 4500 version needs some work in the runners, but I believe the 4500 is better all around in the plenum, and runners. When I first bought my 70 Challenger (back half, ladder bar, lots of fiberglass, 2950lbs with driver) it had a 440 with ported big valve 906s, a .650 lift solid roller, and a team G 4150 with an 850. Glide with 4.56's. It would run 10.90s in good weather, but would creep up to 11.0s in the summer. Since I was racing 10.90 Super Street, I really needed more. I bolted on an ootb M-1, and picked up fifteen hundredths, then the next pass showed two tenths! I never went back to confirm, since I had plenty of runs on the team G. Sold it at a swap meet, and never looked back. has any one have results with a 446-452ci with INDY 440-1s or B1 heads
I'm putting together a 446ci B1 combo
These combinations are very sensitive to getting the camshaft duration, gear, and converter matched up. My brother built a 440 with ootb Indy-1s, 13.2:1, short duration roller (260-269@ .050, .657 lift.), 6100 stall 8 inch JW, glide, 4.56 gear, 15X33 tire, in a 2750lb Barracuda and it went 9.30-143.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: dannysbee]
#2002125
01/30/16 07:17 PM
01/30/16 07:17 PM
Ari440
long island NY
Brad I believe the shift point on the 446 b1 l have was 7800. It pushed 3800 lbs of car 138 mph. The piston speed would be less than a 4.5 stroker turning 6800. care to share more info on this combo compression cam stock or ported heads conveter gears weigth
1.39 9.85 - 137 mph
#2002382
01/31/16 12:36 AM
01/31/16 12:36 AM
Posts: 5,160 Texas
dannysbee
Texas
Ari440 the converter was 5600 or so 8" gear was 4.56 or 488 the heads are ported nicely. It is a nicely built old school engine. It has a girdle that resembles the girdles they used on the old 392 fueler engines a fabricated rev kit, rocker stans are milled off and it has blocks and shims so perfect geometry can be attained. Compression I'm going to say is 13+ to 1.It has healthy domes and small combustion chambers. I have no idea on the camshaft. I traded for the engine so I don't know all the particulars. Sorry
#2002390
01/31/16 12:41 AM
01/31/16 12:41 AM
Posts: 5,160 Texas
dannysbee
Texas
#2002417
01/31/16 01:09 AM
01/31/16 01:09 AM
Posts: 102 Australia
Project kickin A
Australia
current combo is a std stoke .030 440 BG 995 cfm King demon RS on an M1 11.5 to 1 ex rebel Engle solid cam and lifters sidewinder heads with a gasket match and not much else Harland sharps glide with a 4k converter 4.56 gears four link in a duster best so far with the footbrake 1.46 60ft 6.6 1/8th @ 99mph 8.9 1000ft @ 124mph 10.91 1/4 @118mph fuel pump proved to be too small and couldn't keep up.
[Re: Project kickin A]
#2002423
01/31/16 01:17 AM
01/31/16 01:17 AM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
current combo is a std stoke .030 440 BG 995 cfm King demon RS 11.5 to 1 ex rebel Engle solid cam and lifters sidewinder heads with a gasket match and not much else Harland sharps glide with a 4k converter 4.56 gears four link in a duster best so far 1.46 60ft 6.6 1/8th @ 99mph 8.9 1000ft @ 124mph 10.91 1/4 @118mph fuel pump proved to be too small and couldn't keep up Be very careful or you are going to see liquid aluminum running out of the headers. Didn't you feel it laying over
#2002430
01/31/16 01:27 AM
01/31/16 01:27 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Hi Project, Could you tell me what fuel system you had( pump, lines and all ) when it dropped 6mph it the top half ?
1963 Plymouth Max Wedge 1971 Barracuda
#2002475
01/31/16 02:32 AM
01/31/16 02:32 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
It is not uncommon at all to have the stock 440 decks cut on a taper on both sides I've seen .008 on one side taper and .004 on the other side the opposite way Same thing on the rod lengths and crankshaft strokes There was a Pro bracket 2 racer at LACR years ago with a 440 1967,68 or 1969 Baracuda coupe that insisted his car ran the best with a Dominator flang intake with the 2 inch tapered 4150 to 4500 adpater with a Holley 850 DP compared to a Holley 1050 Dominator carb. on the same intake without the adapter As far as tapering the heads, block or intakes to help straighten out the airflows, that is a old SB Chevy SS trick used on the stock iron heads a long time ago, I wouldn't waste my time on a BB Mopar V8 that won't be shifted above 7500 RPM Buy better heads to fix that
