Re: Let's talk Gen 2 Hemi combos!
[Re: cudadoug]
#1999476
01/27/16 12:24 AM
01/27/16 12:24 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Stock stroke.....That's going back a ways....Stock block, stock heads, stock rockers.... 426 +.06 for 431 cubes, compression was around 10.5 or 10.0......KB Hyper pistons, stock heads, no porting, intake was an old cross ram style I had modded with a 1" spacer for the plenum and then 1" spacers under each carb, runners all shortened and radius'd, and I modded the two 750 eddy carbs. Cam was an old roller around .630 lift...Car with 4.10 gears at 3300 went 11.60 at 119mph in street trim with mufflers....Back in '96 or there abouts...
[Re: cudadoug]
#1999495
01/27/16 12:37 AM
01/27/16 12:37 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Why stick with a stock stroke? I would go 4.5, by the time you pay to get a crank ground and new pistons, you are money ahead getting a stroker crank. 4.5 stroke 248@.050 .628 lift crane roller StageV intake, heads, 2.3/1.9 valves, rockers Quick fuel 770 vacuum carbs with annular booster Milodon road race pan with external pickup still cant afford to finish the car though Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1999596
01/27/16 03:48 AM
01/27/16 03:48 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Why stick with a stock stroke? I would go 4.5, by the time you pay to get a crank ground and new pistons, you are money ahead getting a stroker crank. 4.5 stroke 248@.050 .628 lift crane roller StageV intake, heads, 2.3/1.9 valves, rockers Quick fuel 770 vacuum carbs with annular booster Milodon road race pan with external pickup still cant afford to finish the car though Tim I would agree with big inches, but my hemi goodie package includes 2 sets new in the box Pistons, nice hemi rods (all of the old school tricks: peened, polished, resized, ARP bolts, new bushings) and a fresh crank...along with a freshly machined block, all ready to wash and assemble.
[Re: Cab_Burge]
#1999789
01/27/16 03:18 PM
01/27/16 03:18 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
Mine is just a little ole 528" for now.
4.503 Bore Mega Block, Kellogg 4.150 stroke, 7.100 Manley Rods, JE Pistons, Comp .800+ lift custom nitrous cam with 4/7 swap. Block machined to 55MM roller cam bearings, Barton 1.6 valve train with oilers, Indy tunnel ram with two 1050 Dominators, two NOS foggers.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#1999903
01/27/16 06:37 PM
01/27/16 06:37 PM
cudadoug
Good news is that I don't have rockers, so I'd be forced to buy good ones. I am aware the rocker issue is a big one with these motors. I've got OE heads with my pile o parts. Ho hum OE 66-71 heads, fresh VJ and stainless valves and a set of bare 64 K heads. But I'm aware of the gains to be had with new aluminum heads. As for your wedge comment, I've always been a Wedge fan until my last few small block success. That said, I'm just weighing options at this point.
