Holley carb won't idle. NEED HELP! #199836
01/21/09 11:05 AM
01/21/09 11:05 AM
Crowley,TX
70Duster360 Offline OP
super street
super street
Crowley,TX
First, my combo.
360 based 408". 9.9:1 comp.
EQ magnum heads w/2.02 int.
Hughes hyd roller; 236/242 @ .050, .521/.525 w/1.6 rockers, 107 LSA installed at 104.
Air Gap intake and 1 5/8" headers.
Now my problem. When I first put this thing together I had an Edelbrock 600 I used to get it running. I got a used Holley Street Avenger 770. I took it apart, cleaned it and put in new gaskets. I did not see anything amiss but I'm no Holley expert. Well this thing just will not idle. I have to keep the throttle open to keep it running. I did not see any fuel out of the boosters when trying to let it idle only when opening it up. Ideas? Please help. By the way I'm using the Edelbrock now which dosn't idle great but it is drivable.
Re: Holley carb won't idle. NEED HELP! [Re: 70Duster360] #199837
01/21/09 11:11 AM
01/21/09 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull the idle mixture screws and blow air thru the
holes to see if they're open, useing a air nozzle
Re: Holley carb won't idle. NEED HELP! [Re: MR_P_BODY] #199838
01/21/09 11:35 AM
01/21/09 11:35 AM
Q
Quicktree Offline
Quicktree  Offline
Q
first thing you need to do is make sure all of your ignition/timing is right before you go messing with the carb.
Re: Holley carb won't idle. NEED HELP! [Re: Quicktree] #199839
01/21/09 01:00 PM
01/21/09 01:00 PM
Crowley,TX
super street
super street
Crowley,TX
Mr PBODY, all passages were clear.
Quicktree, Initial is at 18 and total is 34. Zero on balancer was checked after degreeing cam. Known good timing light. Using FBO ignition. Parts store control box for now as the FBO box went kaput after a few miles. No difference between the two noticed. Thanks for the help so far!
By the way it has 69 jets in the front and 74 in the back.
Re: Holley carb won't idle. NEED HELP! [Re: 70Duster360] #199840
01/21/09 01:35 PM
01/21/09 01:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
not real up on the avenger, my advice is sell it and get you a 750dp if your going to be racing.
Re: Holley carb won't idle. NEED HELP! [Re: Quicktree] #199841
01/21/09 01:39 PM
01/21/09 01:39 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
whats the lowest rpm it will idle at?
How far open are the throttle plates at that idle? How much of the idle slot is exposed?
Re: Holley carb won't idle. NEED HELP! [Re: 70Duster360] #199842
01/21/09 01:40 PM
01/21/09 01:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And your sure you put the metering block gaskets
on in the right direction, if I remember right if
they are on backwards they closed a port off and it
might be the idle port(but I cant remember what it did)
Re: Holley carb won't idle. NEED HELP! [Re: aarcuda] #199843
01/21/09 02:30 PM
01/21/09 02:30 PM
Crowley,TX
super street
super street
Crowley,TX
aarcuda, the throttle plates were set so the idle slots were square but the throttle had to be held open well beyond that for it to run. Also this is now my daily driver(using the Edelbrock), although if I can get everything right I'd love to take it to the track.
Mr P BODY, I was sure I put the new gaskets right but with me, anything is poss. I will recheck that.
Re: Holley carb won't idle. NEED HELP! [Re: 70Duster360] #199844
01/21/09 02:39 PM
01/21/09 02:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you need to check you manifold vacuum..and adjust your power valve ..
you are probably not generating enough vacuum...that is why you have to open up the throttle blades to get it to run...
your idle mixture screws probably have no effect on the idle????
usuing the fix is to open up the secondary throttle blades a little to help air flow or drill the primary throttle blades...
as noted about a 750 double pumper with 4 corner idle would go along way to getting to idle right...
Tony
70 AARCuda Vitamin C
Re: Holley carb won't idle. NEED HELP! [Re: 70AARcuda] #199845
01/21/09 02:51 PM
01/21/09 02:51 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
I'm going to play worst case scenario here. I purchased a set of 1050 Dominators that I was told went down the track three times. These are the same model as what was currently on my car but I was getting them as part of a tunnel ram set up. On my car - we could not get the tunnel ram to idle at all without holding the throttle open - just like you. We thought there was a huge vacuum leak since the carbs had successfully gone down the track.
We could not isolate the cause. Finally I took the tunnel ram off and put my single back on and tried each carb with my single - they would not idle. My original carb idled just fine and it was the same model number with the same jets. We pulled the carbs apart multiple times and could not find any issue.
So, at the end of my rope, I sent them to Jesse Bigs and he found the problem - of the 4 metering blocks - only 1 of them was fully drilled. There is no way they ever went down a track.
If you are at the end of your rope - get the metering blocks checked.
Re: Holley carb won't idle. NEED HELP! [Re: Lil Demon] #199846
01/21/09 03:13 PM
01/21/09 03:13 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i see where you said the holley was used?
do you know the history of this carb?
nothing worst then trying to fix a bad carb...
Tony
Re: Holley carb won't idle. NEED HELP! [Re: MR_P_BODY] #199847
01/21/09 03:38 PM
01/21/09 03:38 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Mr.P is correct as I have made this mistake.Having the gasket the wrong way will not let it idle and this was on a 950 Holley
Re: Holley carb won't idle. NEED HELP! [Re: 70Duster360] #199848
01/21/09 03:42 PM
01/21/09 03:42 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A couple of issues..
1. Power valve, the 770 AV comes with a #65. If your vacuum is low due to cam timing, most likely will need to drop this down to a #45 or #35.
2. The squirters used in the 770 AV are smaller than those in the 650 AV, we have found that we had to take this up about 3 steps.
Also once you get things dialed in closer, most likely you will need to put a liter spring in for the secondaries. Or you may want to consider Qwik Technology adjustable diaphram for the secondaries dial it rite in.
Hope that helps...
Re: Holley carb won't idle. NEED HELP! [Re: Sinitro] #199849
01/21/09 08:14 PM
01/21/09 08:14 PM
Crowley,TX
super street
super street
Crowley,TX
Vacuum is 13" - 14". I'm going to pull it apart and check gaskets in the morning.
Re: Holley carb won't idle. NEED HELP! [Re: Sinitro] #199850
01/21/09 11:33 PM
01/21/09 11:33 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Hope that helps...
Power valve and squirters have nothing to do with idle. Do your self a favor and go to the holley web site, lots of info and pics.
Here ya go.http://www.holley.com/TechService/Library.asp
Re: Holley carb won't idle. NEED HELP! [Re: Blown61] #199851
01/22/09 01:04 AM
01/22/09 01:04 AM
Lil Demon Offline
Lil Demon  Offline
I still say you had better get the metering blocks checked. DAMHIK
Re: Holley carb won't idle. NEED HELP! [Re: Blown61] #199852
01/22/09 02:50 AM
01/22/09 02:50 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Hope that helps...
Do you understand the basics for the power valve operation..
Power valve tuning considerations require that the power valve should only open at wide open throttle not at idle..
Here the key is to ensure that idle vacuum does not drop below the power valve opening point.
For example..
Eratic, rough idle and over-rich condition is caused by an 8.0 idle vacuum and a power valve rated 10.5 inches of manifold vacuum. Note that a big cam w/overlap can/will drop the idle vacuum down below 8 inches.
Next Holley question please...
Re: Holley carb won't idle. NEED HELP! [Re: Sinitro] #199853
01/22/09 11:57 AM
01/22/09 11:57 AM
Andrewh Offline
Andrewh  Offline
It isn't if the gaskets are in wrong, but did you put the right ones in.
The holley kits are for multiple carbs, and if you put the wrong set in, it blocks off the idle circuit.
Been there done that. One of the gaskets at the metering block did not come out in one piece for me so I guessed, and chose poorly.
Re: Holley carb won't idle. NEED HELP! [Re: Andrewh] #199854
01/22/09 12:48 PM
01/22/09 12:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check fuel pressure and bowl height. look down the carb and see if fuel is running while at idle.
Re: Holley carb won't idle. NEED HELP! [Re: Sinitro] #199855
01/22/09 12:54 PM
01/22/09 12:54 PM
AndyF Online content
AndyF  Online Content
If the carb is adjusted properly then the power valve doesn't have any effect on the idle circuit. It doesn't matter if it is open or not at idle as long as the throttle blades are in the right spot. BUT, having the wrong power valve in there can mess up the carb in other ways so he should of course have the correct one in there.
It sound to me like the idle circuit isn't working right for some reason. It could be as simple as the throttle blades open too much or it could be something like a blocked passage. Hard to trouble shoot over the internet either way.
