Re: Can you go racing by yourself, and if not WHY
[Re: pittsburghracer]
#1998227
01/25/16 08:30 AM
01/25/16 08:30 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Only have a slow street/strip car that I run brackets with, no trailer, load up the tools in the trunk and head to the track.
I used to race sportbikes, and would have everything loaded onto a tiny open trailer and the back of my Jeep. It was important to streamline the simple stuff (loading/unloading, finding tools, etc) so I could spend more energy on tire/shock tuning and getting my head in the game. As someone else mentioned, a routine that is second nature helps immensely.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: bonefish]
#1998262
01/25/16 11:24 AM
01/25/16 11:24 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks for the tips on the nitrous side of the equation. I will probably take the car out for some NA hits early season to make sure the small block to big block switch-over went well and start slowly adding power. My Son Matt will be with me on some occasions but with him racing to we try to run our own program as much as possible. PRP (now Keystone again) has track rentals almost every Friday during the Summer but they are early in the day before our regular test n tune sessions so its harder to round up help.
[Re: skicker]
#1998285
01/25/16 12:03 PM
01/25/16 12:03 PM
Posts: 7,506 Az
Crizila
Az
Mine was a dirt car and differs significantly but for me being organized was key. Most of the tasks that were more detail oriented had to be made idiot proof if others decided to help. Tool placement always the same...small things like your line in the trailer will make things more manageable. Look on the bright side...you don't have to scrape off mud and stack tear-offs on the helmet... I may be up to a few races next year at PRP...I can help some and maybe learn too... for sure on the being organized thing. Had my racing check list that I always used( and constantly in flux ). Wife made her own check list for the track - included tires, belts /hoses, fuel, lights for night races, blower lube, loading/unloading. She also logged the runs, comments, and any changes we made between runs. Ya, no tear-offs, but I did paint a line on my trailer floor for loading / unloading consistency. Like staging, having a consistent routine helped. BTW, I love sprint car racing - I could have missed my calling.
Fastest 300
#1998302
01/25/16 12:32 PM
01/25/16 12:32 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I'm not usually alone at the track, but I do everything to the car myself. It was much easier running naturally aspirated. Nitrous adds a lot of work, but it's worth it, lol.
For a normal bracket car, I don't see any reason you couldn't do it all by yourself.
[Re: dvw]
#1998311
01/25/16 12:50 PM
01/25/16 12:50 PM
Posts: 16,928 NC
440Jim
NC
I'm 61 and do it by myself. Enclosed trailer so I crawl through the window to get the car out. Doug I see several posts about crawling out the window. I hope to avoid that with my new enclosed trailer with a driver side escape door. I noticed many trailers have the bottom of that about 11.5 to 12 inches off the floor, and some car doors are lower. My United trailer has the escape door 9.5 inches off the floor, so my next race car needs to clear that. My previous Dart would, Just to clarify, my new trailer escape door is 9.5 inches off the floor with the trailer fender 7.75 off the floor and 1.75 for the escape door frame. Then there are tube chassis racers that take off the drivers door and hang it on the wall before pulling into the trailer.
#1998312
01/25/16 12:53 PM
01/25/16 12:53 PM
an8sec70cuda
I can drive my cuda in my enclosed trailer and get out, but I still have the factory roll down windows. If I had fixed lexan windows, it wouldn't be possible...for me anyway. I'm 6'5" and 320 lbs.
[Re: 440Jim]
#1998316
01/25/16 01:04 PM
01/25/16 01:04 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I'm 61 and do it by myself. Enclosed trailer so I crawl through the window to get the car out. Doug I see several posts about crawling out the window. I hope to avoid that with my new enclosed trailer with a driver side escape door. I noticed many trailers have the bottom of that about 11.5 to 12 inches off the floor, and some car doors are lower. My United trailer has the escape door 9.5 inches off the floor, so my next race car needs to clear that. My previous Dart would. my tube chassis cuda was to low to clear the trailer fender where the escape door was so just screwed a 2x10 plank to the floor and it raised it up enough to clear.i just did it on the drvers side but if you leave your car in the trailer for storage you may want to raise both sides so it sits level.
[Re: an8sec70cuda]
#1998319
01/25/16 01:08 PM
01/25/16 01:08 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I can drive my cuda in my enclosed trailer and get out, but I still have the factory roll down windows. If I had fixed lexan windows, it wouldn't be possible...for me anyway. I'm 6'5" and 320 lbs. Wholly crud. Note to self, never ever ever start crap with this guy. Hey LOVE your car.
[Re: an8sec70cuda]
#1998321
01/25/16 01:19 PM
01/25/16 01:19 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I can drive my cuda in my enclosed trailer and get out, but I still have the factory roll down windows. If I had fixed lexan windows, it wouldn't be possible...for me anyway. I'm 6'5" and 320 lbs. wholly crud!!! your pretty agile for a big boy.Any relation to Houdini?
#1998328
01/25/16 01:25 PM
01/25/16 01:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being that I race small cars I can drive into the trailer and still get out without any issues... my hardest thing is some times I have to crank up the landing leg so I can clear the angle at the door and the ramp.. thats also with 7' alum extension ramps that are mounted to the door
[Re: plycuda]
#1998339
01/25/16 01:36 PM
01/25/16 01:36 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
why don't anyone use a winch to pull the car in and out. a lot easier than climbing out the window Not for me it isn't. I have a brand new remote control winch and its there for emergencies (breakage) and for my later years when I get old.
[Re: plycuda]
#1998347
01/25/16 01:46 PM
01/25/16 01:46 PM
MR_P_BODY
why don't anyone use a winch to pull the car in and out. a lot easier than climbing out the window I use to winch my car in backwards to balance the load.. but I changed things around in the trailer so I pull in now... the winch is just for break downs now days.. I cant remember when I last used it
#1998382
01/25/16 02:21 PM
01/25/16 02:21 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I always winched my car in the trailer.........never once drove it in. Winch is easy.........just takes an extra 10 minutes. Is everybody in such a hurry that 10 minutes is a killer
On cars with glass doors and lexan windows. If you want to drive it in the trailer, just remove drivers door and make a rack on the wall to hold it.
#1998395
01/25/16 02:45 PM
01/25/16 02:45 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
We had a guy get seriously hurt this past year out at Bremerton loading his car by himself. Not really sure how it happened, but afterward track officials asked everyone to please not attempt to load your car by yourself. Ask for help, and help when asked. I guess the guy broke his leg pretty bad, somehow got pinned between the car and the trailer.
[Re: StealthWedge67]
#1998461
01/25/16 04:06 PM
01/25/16 04:06 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
The doors will come off that car in a sec John. You might see about making a bracket that you can hang it on the wall of the trailer so you can drive in and get out. I had a mount in my trailer and took the door off everytime in and out so crawling out was easy when you drove it in there. Just something to think about.
One day I will have something cool here.
