tire size for track
#1997140
01/23/16 05:25 PM
01/23/16 05:25 PM
Posts: 347 FRANCE, Paris
Chal340
FRANCE, Paris
I would like to buy tires to go on the track with my Challenger. It's a street car but want to go to on a real track this summer in UK ( SantaPod ).
416 ci with weiand Xcelerator, 727 with Transgo TF2, rear end 3.73 + Gear vendors. I shift at 5800-6200. Converter is 2500 Edelbrocks heads with 0.525 camshaft and 237 duration. prosystem carburetor 850 cfm DP
Today my best time with street tires, Avon CR6ZZ, track was not good. diameter of tire, 27", 275x55x15.
13.02 @ 110 Mph, 60'@2.25
What diameter and width do you think? And Slick or quick time pro?
thank you
70 Challenger, A66, 340 ci
Re: tire size for track
[Re: Scott58]
#1997623
01/24/16 01:08 PM
01/24/16 01:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a 295/55 and that puts it through the traps at 7000 rpm with a 4.10 gear.. with a GV you have to be damn near at idle at 75 mph.. I am 2900 rpm with my 518 in OD(no lock up)at 75 mph.. if I went much lower it would hurt MPG with the cam I run
[Re: sgcuda]
#1997633
01/24/16 01:30 PM
01/24/16 01:30 PM
Chal340
FRANCE, Paris
It would really help if we knew what gear and what rpm you were crossing the line at. This info would determine tire height. When I cross the line, I'm in the 3rd gear and at 5100-5200 rpm. Today I run with my street tires, 27" diameter.
[Re: Chal340]
#1997639
01/24/16 01:33 PM
01/24/16 01:33 PM
Chal340
FRANCE, Paris
I don't want to change my rear end because this summer I'm goint to make more or less 4000 miles to go to the different tracks and holidays.
These new tires are only for the track.
[Re: Chal340]
#1997644
01/24/16 01:42 PM
01/24/16 01:42 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Well then, you sure don't want a taller tire (60 series). If you are keeping the same gears, you will need to lower your tire diameter. Tire sizes along the lines of what Stealthwedge67 recommended. If the widest you could fit is a 275 tire width, see if there is a 50 or 45 series profile, which would give you a lower sidewall/overall diameter. This would give you both, lower 60 ft. and higher trap rpm.
[image][/image]
[Re: MR_P_BODY]
#1997649
01/24/16 01:46 PM
01/24/16 01:46 PM
Chal340
FRANCE, Paris
I run a 295/55 and that puts it through the traps at 7000 rpm with a 4.10 gear.. with a GV you have to be damn near at idle at 75 mph.. I am 2900 rpm with my 518 in OD(no lock up)at 75 mph.. if I went much lower it would hurt MPG with the cam I run Yes, on the highway, I'm at 3000 rpm for 83 Mph. I don't want to change because many miles this summer and in France, gas is very expensive around $6 for 1 gallon.
[Re: sgcuda]
#1997651
01/24/16 01:53 PM
01/24/16 01:53 PM
Chal340
FRANCE, Paris
Well then, you sure don't want a taller tire (60 series). If you are keeping the same gears, you will need to lower your tire diameter. Tire sizes along the lines of what Stealthwedge67 recommended. If the widest you could fit is a 275 tire width, see if there is a 50 or 45 series profile, which would give you a lower sidewall/overall diameter. This would give you both, lower 60 ft. and higher trap rpm. My actual tires, Avon, are only for the street. If I bought 26' diameter, I will be at 5500 rpm for 114 Mph. Maybe I have to change my converter, 3000 instead of 2500. If I change it, it will be always ok, 3000 stall on the highway?
[Re: Chal340]
#1997693
01/24/16 03:13 PM
01/24/16 03:13 PM
sgcuda
Just like any other aspect of racing, make one change at a time. I would try a set of race only tires first. Changing torque converters can only make fuel consumption and highway rpm worse. 114 mph trap speed should put you well into the 12 second bracket.
[image][/image]
[Re: Chal340]
#1997809
01/24/16 06:17 PM
01/24/16 06:17 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
Based on the differences in track surfaces and track preperation from here in the U.S. to those tracks in Europe, based on actual expereinces when I was assign to duty in Hanua, Germany. I would buy a bias ply tire, not a radail No matter the tire size I built and raced a semi fast pump gas street and strip Duster(ran high nines in the 1/4 on pump gas motor only with the exhaust and air cleaner on ) and used both M/T ET Street(bias plys) and M/T ET Street Radials of the same exact size as well as using a set of M/T 10.5x31x15W drag slicks, the slicks where the best at the track as far as ET and MPH, the Radials where faster on a good track than the bias ply tires where but on a not prepared well track and on the street the bias plys where way better Buy the biggest size that will fit on the car and use the widest rim you can get on the car, even if the rim is wider than the tire thread width is IHTHs IHTH
[Re: Chal340]
#1997819
01/24/16 06:33 PM
01/24/16 06:33 PM
Posts: 570 UK
rb446
UK
Hi, for Santa Pod Proper 26" Bias Ply Drag Slick will be best, or a radial slick perhaps as they now prepare the track some for RWYB's. Your right on with 5500rpm/114mph, unfortunately I doubt with that 2500 converter you will run the 11.6's that mph equates to?......always a trade off for street/strip....I used to run a '71 Cuda 340 on the street with a 4200 verter and 4.30 gears w/26.5" road tyres, 50mph was 4000rpm, didn't run that too often down the Highway!!!
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: sgcuda]
#1997891
01/24/16 08:06 PM
01/24/16 08:06 PM
Chal340
FRANCE, Paris
Thank very much guys. I'm going to order them.
[Re: 383man]
#1998213
01/25/16 05:36 AM
01/25/16 05:36 AM
Posts: 2,917 A shed in England
Tig
A shed in England
With stock spring location and stock ride height I used to get a 29 x 10 slick on an 8 inch rim in there, can't remember the back spacing but it was pretty close to the lip of the rear arch and the leaf spring, IIRC it touched the spring when turning the corners. You should be ok with the 26 x 8.5 but you may foul the tyre somewhere with a 26 x 10 slick depending upon the wheel offset. A 10 inch slick can have a 12 inch shoulder width. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
