Difference in alt brackets between BB and Hemi
#1996686
01/22/16 11:33 PM
01/22/16 11:33 PM
Posts: 12,036 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have plenty of alternator brackets off 440s. (non A/C of course) And am now in the process of prepping a Hemi to replace the Wedge. I am using a balancer that places the pulleys in the wedge location rather than the Hemi location. So can I use the 440 brackets on the Hemi? I know the Hemis used a straight adjuster arm rather than the curved one on the wedges. How much of the 440 stuff can I use? The adjuster arm, triangle bracket? Thanks!
Master, again and still
Re: Difference in alt brackets between BB and Hemi
[Re: DaveRS23]
#1996851
01/23/16 06:07 AM
01/23/16 06:07 AM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
I'm running regular standard non a/c big block alternator brackets on mine. Like you my harmonic balancer (BHJ) is designed to run regular big block pulleys. Uses standard big block belts too. I have no problems with alternator fit or clearance.
[Re: DaveRS23]
#1996903
01/23/16 12:12 PM
01/23/16 12:12 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
That's what I was hoping. I'm using a BHJ damper, too. And I just located a Federal pump and bracket in the stash that I didn't even know I had. My Shaker will cover much of the engine, so I am not real concerned about what it looks like under there. But I kinda like what can be seen around the Shaker to look fairly OE, just for fun.
You're a lot farther along than I am with my project. My block is at the machine shop now. Hope to have it back next week or two.
It would be nice to have mine turn out as nice looking as yours.
