Removable Front End (stock style/multi-piece) #1994517
01/20/16 12:12 AM
01/20/16 12:12 AM
Parts unknown
590 Challenger Offline OP
Parts unknown
I'm removing my inner wheel wells. It's opening up some access. I would like to take a bigger advantage of by also making my stock style front end completely removable like a one piece. I have some good ideas and I'm sure I'm not the first to do this. I'm hoping to see what others have done so I can incorporate their good ideas too
Thanks,
Jeff
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1994616
01/20/16 01:34 AM
01/20/16 01:34 AM
My chromoly tube frame(A arm coilover front suspension) 1970 Cuda has the original steel front fenders,stock steel upper and lower valances with a stock grill rivited into a bunch alumimun support and inner fenderwells and so on. It slides off the front after removing two Dzuz fasterners on the moved back steel firewall and the lower four bolts that hold the back of the fenders to the stock rocker panels shruggy It is auckward(SP?) to remove even with two people due to having to raise the fenders up to clear the front tires but it is worth it when needing to work on the motor like checking the valve lash and so on thumbs The aluminum inner fender wells basically hold the front end together thumbs
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1994630
01/20/16 01:54 AM
01/20/16 01:54 AM
Parts unknown
Parts unknown
Thanks I would love to see some pics. I don't have the upper valance and can tie it through the grill. Does your bumper come off with yours somehow? or do you have to remove it separately?
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1994725
01/20/16 04:55 AM
01/20/16 04:55 AM
It has a glass front bumper mounted to the front group, it all slides off as one peice. The hood is fibreglas also and it lifts off seperatily thumbsI need to figure out how to attach pictures on here now, I haven't been able to since the change over last year to the new software runaway realcrazy I don't think I have any pictures of the front end off the car on a memory stick but I will check in the morning to make sure. The car is in the car trailer with 14 inches of snow in front of it right now. Send me a E mail to cabburge@wans.net with Cuda front end pictures in the subject line and I will send you any pictures I have of the car with the front end on and off on the reply, hopefully that will help shruggy
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1994756
01/20/16 10:27 AM
01/20/16 10:27 AM
Parts unknown
Parts unknown
That will help quite a bit thanks I'll shoot you an email. Mine is the opposite of yours, fiberglass fenders, valance and with a steel bumper. I hope there is a few on how you tied the bumper into the mix.
on posting pictures just go to photobucket.com and set up an account. Afterwards you upload your pics there. Then copy and paste the stuff in the IMG box on the right.
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1995154
01/20/16 09:24 PM
01/20/16 09:24 PM
USA
streetking Offline
streetking  Offline
USA
Mine is all together with fiberglass panel glue
Re: Removable Front End (stock style/multi-piece) [Re: streetking] #1995159
01/20/16 09:42 PM
01/20/16 09:42 PM
Western Md.
skicker Online tonguue
"The Champ"
skicker  Online Tonguue
"The Champ"
Western Md.
My plan is a little different than yours but if this helps I'll share.
I'm building a 65 AWB Coronet...reaching it to work on will be a huge PITA.
I used the factory end of the original frame and attached it to a set of leaf spring slider brackets attached to the new frame added for the chassis.
That allows the factory radiator support, fenders, bumper, grill and hood to be slid forward in one piece.
I'm doing mine as a flip nose but could easily be removed by taking out the two front bolts in the sliders.
Mine is still primitive and I haven't worked out all the bugs yet.
Here's a pic of what I have come up with so far...
...FAFO...
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1995172
01/20/16 10:07 PM
01/20/16 10:07 PM
Jerry Kathe Offline
Jerry Kathe  Offline
[img:center][/img]
With this build I chose to use the street weight individual fiberglass panels that were previously used on the car with a stock front clip. I salvaged and chopped up the core support to use as the main mounting structure. It is secured to the upper cowl and front of rocker with quick fasteners. Its not exactly a light weight one piece, but it didn't cost anything other than time and it is a one piece I can manage by myself.
It looks much nicer finished, but I don't have any photos.
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1995177
01/20/16 10:27 PM
01/20/16 10:27 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If the radiator is mounted on the chassis, a core support is useless. It serves no purpose other than to be heavy. All you need is some tubing to hold the fenders together and a bit of a lower frame to mount the nose to the car.
If you look at Jerry's pic, the stock core support he has left could easily be done from round tubing, mount right at the front of new rails and is likely less work. Unless you just WANT a factory looking support, which some do
Re: Removable Front End (stock style/multi-piece) [Re: Monte_Smith] #1995187
01/20/16 10:46 PM
01/20/16 10:46 PM
Jerry Kathe Offline
Jerry Kathe  Offline
It also mounts the grill and filler panel, after trimming it down the remaining core support doesn't weight much of anything, its the fiberglass fenders that are heavy. These pieces are about four times the thickness of race weight fiberglass. I considered your suggestion from the start, but this is stuff is bolt together and like I said didn't cost anything but time.
This gig still uses stock headlight buckets, grill, steel filler panel etc.
If I had the extra coin I would have purchased a one piece and went the tube support route.
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1995220
01/20/16 11:40 PM
01/20/16 11:40 PM
Parts unknown
Parts unknown
Thanks guys, you have given me some good ideas. I like keeping a little of the core support for now to. I still have the stock grill, head light buckets, ect. gives a place to tie it all together. It will be a lot lighter when I'm done with it. Also the pics helped solve other issues.
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996136
01/22/16 05:06 AM
01/22/16 05:06 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
I'll post some pics....ours use factory bumper brackets as our sliders...small square tubing frame...all lights...grill...etc retained...one hood pin on lower fender and 4 hood pins on hood is all that holds the whole front end on.
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996162
01/22/16 09:32 AM
01/22/16 09:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A Challenger grille and headlamp buckets all attach mainly to the fenders. Core support only needed to tie the fenders together.
Doug
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996470
01/22/16 06:35 PM
01/22/16 06:35 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
In the upper left you can see the square tube recievers we built...just like a trailer hitch only smaller....thats what keeps the front end stable..
Grill area showing tubing frame that holds the grill and fenders....
4 hood pins and 1 lower hood pin is all that holds the whole nose on the car...
Little more detail on the frame ....supports headlight bucket...my dad made new reciever plates ....I used the factory bumper brackets on mine....just slotted the factory holes out like a tuning fork...then used longer bolts.
Radiator stays mounted via a tubing frame across the rails and the upper rods to stabilize it....it doesnt even wiggle...
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996472
01/22/16 06:38 PM
01/22/16 06:38 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
With the way we did it we removed the lower front splash apron.... I can remove the engine and trans from the car in 37 mintues...
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996539
01/22/16 08:18 PM
01/22/16 08:18 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
My front end is all bolted together Unlimited components. What do you guys use to adhere the metal structure to the fiberglass. Streetking mentioned fiberglass panel glue. I don't know anything about working with fiberglass. Is this a good adhesive for the metal mounting plates? Is this a common adhesive from an auto body supply?
[image][/image]
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996550
01/22/16 08:29 PM
01/22/16 08:29 PM
Parts unknown
Parts unknown
Chassisman, I really like how you tied yours together to the bumper brackets. Thanks for the pics
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996559
01/22/16 08:50 PM
01/22/16 08:50 PM
Parts unknown
Parts unknown
I'll keep the top of the radiator support and chop off the bottom, It ties the fenders together and also lines up my hood supports I made. Challenger hoods hang over a ways and I have a rather large hole in the center. I don't want it to split in half
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996589
01/22/16 09:21 PM
01/22/16 09:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine is a stock front with a carbon fiber hood
that comes off as 1 piece.. it slips into the
main rails on the tube chassis.. sorry no pics
wave
Re: Removable Front End (stock style/multi-piece) [Re: 590 Challenger] #1996610
01/22/16 09:50 PM
01/22/16 09:50 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
....thanks...that's my Dad's car....mine has a little less tubing....he OVER builds everything.....
