Re: E-85 build
[Re: BuckeyeBrawler]
#1996212
01/22/16 12:26 PM
01/22/16 12:26 PM
dartman366
Mt. Vernon, Ohio
I have no experience with 8 E-85 but thinking about build for street car with a 383. What is safe comp ratio. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Old school build probably will use Mopar .590 cam, ported 906 heads. I've got a set of Arias .060 domed pistons, but currently have done no math to figure comp ratio. Your thoughts are appreciated when I was using E-85 in my drag car, I had 13.0-1 comp and had 32* total and had no problems with it.
Re: E-85 build
#1996277
01/22/16 02:06 PM
01/22/16 02:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With E-85 you have basically 105 octane so base the compression on that... shoot for a cranking pressure about 195 but this is also based on full E-85 summer fuel.... if you let it sit for weeks you should drain the system otherwise it will obsorb moisture and that corrodes... also check the fuel you will be buying(you can get a cheap tester).. some stations tend to have a good mix and others dont... if you buy it and put it in drums for later use make sure its in sealed drums ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: E-85 build
[Re: b1dartsport]
#1996444
01/22/16 06:05 PM
01/22/16 06:05 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
AJ Casini at Bob George Racing can convert any Holley carb to E85. Not sure about other makes. AJ did mine, I will use him again for other carb. conversions ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
Re: E-85 build
#1996708
01/22/16 11:58 PM
01/22/16 11:58 PM
Posts: 181 Maryland
twayne24365
Maryland
I have the pretty much exact build, .030 over arias dome pistons, .590 Mopar cam, 516 heads bowl blended, 2" headers, street dominator intake and an 850 Holley. It's about 11.5:2 and I am going e85 as well. I talked to Eric at horsepower innovations and he is going to build my 750 mighty demon when it gets to that point. I just got it fired up and broken in today, here it is http://youtu.be/LseOzXMxxcc
