Bearings and fingerprints #199510
01/20/09 09:18 PM
01/20/09 09:18 PM
Finally a HUSKER again
Moparnut426 Offline OP
So I have heard from many OLD SCHOOL guys including my dad who have told me that finger prints on bearings will cause pre mature failure.
Have any of you guys ever accually had this happen, or have seen it in person.
Kasey
Re: Bearings and fingerprints [Re: Moparnut426] #199511
01/20/09 09:41 PM
01/20/09 09:41 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I've heard the same. Isn't it something about the acid on your skin {like from sweating}that can eat into the bearing coating??
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Bearings and fingerprints [Re: KatFysh] #199512
01/20/09 09:50 PM
01/20/09 09:50 PM
Thats what dad said, My acidy finger tips....
Re: Bearings and fingerprints [Re: KatFysh] #199513
01/20/09 09:53 PM
01/20/09 09:53 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
With respect for your dad, and the old school guys who think that,,,come on, think about where that bearing is going, and what's going to happen to it immersed in oil and combustion by products at 200 degrees while simultaneously being hammered by combustion shocks thousands of times per minutes for years at a time.
Re: Bearings and fingerprints [Re: dthemi] #199514
01/20/09 09:59 PM
01/20/09 09:59 PM
I agree, I was just curious what you guys thought, I thought about the hammering, and the oils, and fuel, and heat also.
Re: Bearings and fingerprints [Re: Moparnut426] #199515
01/20/09 10:03 PM
01/20/09 10:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There are acids that build up in the oil... but I
always wiped my prints off of the bearing surface,
habit, but... I'm old
Re: Bearings and fingerprints [Re: Moparnut426] #199516
01/20/09 10:09 PM
01/20/09 10:09 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I just wash them, oil'em and install them.(After checking clearances.)
About a thousand years ago when I was an Apprentice Millwright, our bearings and drives instructor, (he owned a bearing house and was as good a bearing man as I've ever met) told us a little story. It seems one of the bearing manufacturers of anti-friction ball bearings, (SKS, Bower, Timkin) once in a while would get a complaint about rusty fingerprints on their new unused bearings. Their engineers were pulling their hair out trying to figure out why it only happened sporaticly. Finally after a long exhaustive study they figured it out.
They hired women to wrap and package the bearings. Once a month as each women went into their menstrual cycle their sweat became more acidic which stained and etched the bearings. To solve the problem they begain requiring everyone on the packaging line to wear gloves. Dave
Re: Bearings and fingerprints [Re: quickd100] #199517
01/20/09 10:46 PM
01/20/09 10:46 PM
VERY interesting... Thats crazy, thanks for the info. Its amazing what a guy learns on moparts.
Re: Bearings and fingerprints [Re: Moparnut426] #199518
01/20/09 11:07 PM
01/20/09 11:07 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Had to go the monthly thing though huh?? Raff, yer not as old as the guys we're referring to..
Re: Bearings and fingerprints [Re: Moparnut426] #199519
01/20/09 11:26 PM
01/20/09 11:26 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I know in jet engines finger prints are a problem on the ball bearings. At over 10,000 rpms the prints contain salt and acids that caused galling and ruined the bearings and the race. There was a finger print remover that they used. So myth proven no BS.
Re: Bearings and fingerprints [Re: Moparnut426] #199520
01/21/09 02:04 AM
01/21/09 02:04 AM
I wipe all bearings inserts off with laquer thinner(front and back) and then use a drop of oil on the bearings, then I do use my ungloved finger tips to spread the oil onto the bearing suface and on the cranksaft bearing suface area before installing the rods and mains onto the crankshaft. You cannot be to careful when it comes to assembling a motor, it is like brain surgery, it is impossible keep it to clean
Re: Bearings and fingerprints [Re: Cab_Burge] #199521
01/21/09 09:30 AM
01/21/09 09:30 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have brand new bearing that have been contaminated by fingerprints and have deterioated the bearing so baddly that they are unusable.We have them at the shop to show people,maybe Allen Ross(shop photo spy) will take some pictures and post.We have also seen new blocks that were cleaned and handled in the bores that had rusted the walls bad enough that honing would not clean them up. go figure.
Re: Bearings and fingerprints [Re: B G Racing] #199522
01/21/09 09:35 AM
01/21/09 09:35 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I was always told the same thing and I made sure I didn't touch them with my bare hands after I cleaned them for assembly on my current Engine. I was at BG's place and saw that bearing the other day. You could see the print plain as day and the bearing had damage.
Re: Bearings and fingerprints [Re: RonP] #199523
01/21/09 09:58 AM
01/21/09 09:58 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Any layered clevite style bearing taken out of package & left out in air without oil or something protective on it can deteriorate. I've had a bunch sit out just maybe for a few weeks out of package in summer when humidity is in the 50's or higher in the shop & bearings will be ruined. That's why I never take them out of protective wrapping until I'm ready to use them, & I have mock up bearings that I keep lubed that sit around exposed.
So it wou;d'nt surprise me if the acid from your prints if left on a bearing that did'nt go into a motor could do some damage over time especially in a humid environment, the acid can actually draw in moisture to the bearing & start it to rust etc. Same deal on my car right now it has been in bare steel for like 6+ months... it does not rust anywhere except if you put your hands on it somewhere & leave fingerprints or a palm print etc after a while they will start to show up..... so my car has little rusty fingerprints & palm prints on it in certain areas. Anywhere I never touched with bare hands since stripping it to steel, it is still as clean as day I stripped it..... humidity etc never affected it.
Most people who are touching bearings are going to be putting them in the engine within at least a few hours, & tehy're gonna be doused in some type of lube which will wash away the very minute acid from the skin....So I do not worry about touching the shell of the bearing when I'm handling them (not that you really need to be handling the shell itself, usually I'm touching the edges only when holding a bearing or installing) But I do believe as I said if you leave them sit out for long time after touching them they can get ruined without some type of lube on them.
I don't think this would much apply to a King or Federal bored aluminum bearing, just Clevite type layered bearings.
Re: Bearings and fingerprints [Re: quickd100] #199524
01/21/09 10:11 AM
01/21/09 10:11 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Hmmm, oozing acid out of their skin once a month?? That sounds about right.....
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Bearings and fingerprints [Re: RyanJ] #199525
01/21/09 10:13 AM
01/21/09 10:13 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
But the ones we are talking about came out of the box brand new.And let me caution people that use lacquer thinner on layered bearing. The layers have their own lubercating qualities and pliability qualities,such as found in babbit,aluminum,brass and copper and other non ferris materials.The lacquer thinner penatrates and dries and can cause premature failures.
Re: Bearings and fingerprints [Re: Moparnut426] #199526
01/21/09 12:01 PM
01/21/09 12:01 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I did jet engine ball bearing inspection for Uncle Sam years ago and part of the process was dunking the bearing in "finger print remover" before packaging it up. There must be something to it. I don't remember what chemical the finger print remover actually was and didn't smell like any familiar chemical .
Re: Bearings and fingerprints [Re: 446acuda] #199527
01/21/09 12:07 PM
01/21/09 12:07 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There is,I dunked my fingers a few time and used a sented hand cleaner to get that familar smell off them. That didn't come out the way I intended But it certainly saved my butt a few times
Re: Bearings and fingerprints [Re: B G Racing] #199528
01/21/09 12:23 PM
01/21/09 12:23 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Bob, you are killing me
oh by the way empty your pm's so I can bug ya some more.
Re: Bearings and fingerprints [Re: RonP] #199529
01/21/09 12:32 PM
01/21/09 12:32 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Can't never be too careful,I get the sniff test everytime I come home,by 3 dogs and the wife.Remind me to tell you about the dog humping my leg one night and after I changed cloths he got the jeans out of the hamper and proceeded to molest them infront of Debby,If looks could kill PMs empty,wondered why it was so quite.
