Trick Flow intakes open for orders #1994250
01/19/16 06:18 PM
01/19/16 06:18 PM
AndyF Online content OP
AndyF  Online Content OP
Summit has the Trick Flow intake manifold available to order with a ship date of 2/29
Not sure what that means but at least the part number is now showing up. There is also a low deck intake with the same ship date. I'm going to order one just to see what happens.
http://www.summitracing.com/parts/tfs-61600113
Re: Trick Flow intakes open for orders [Re: AndyF] #1994286
01/19/16 07:07 PM
01/19/16 07:07 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I will be waiting for the results before I make my decision on which one I am going to use, engine won't go in the car till next winter anyway. thumbs
Re: Trick Flow intakes open for orders [Re: AndyF] #1994684
01/20/16 03:14 AM
01/20/16 03:14 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Sure looks like an Eddy Victor.
Re: Trick Flow intakes open for orders [Re: StealthWedge67] #1994718
01/20/16 04:31 AM
01/20/16 04:31 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I was waiting for someone else to say it. Could you imagine the bashing that would be going on if that was made in China? stirthepot
Re: Trick Flow intakes open for orders [Re: StealthWedge67] #1994890
01/20/16 02:26 PM
01/20/16 02:26 PM
KS
Cogito Offline
Cogito  Offline
KS
The TF appears to have a nicer plenum out of the box.
Re: Trick Flow intakes open for orders [Re: Cogito] #1994893
01/20/16 02:27 PM
01/20/16 02:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
In my mind the pad/roof needs LOTS of work like most of em..........
Re: Trick Flow intakes open for orders [Re: AndyF] #1994978
01/20/16 04:30 PM
01/20/16 04:30 PM
Sounds like they will be shipping in the near future. I'll get it on the dyno as soon as it shows up.
Re: Trick Flow intakes open for orders [Re: AndyF] #1995007
01/20/16 05:05 PM
01/20/16 05:05 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I wish the TF RB intake was shorter than a Victor, but it looks just as tall.
Re: Trick Flow intakes open for orders [Re: BradH] #1995069
01/20/16 06:11 PM
01/20/16 06:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why, short intakes equal poopy power and most add spacers anyhow........
Re: Trick Flow intakes open for orders [Re: Thumperdart] #1995096
01/20/16 07:03 PM
01/20/16 07:03 PM
BradH Offline
BradH  Offline
It's still gotta fit under the hood with an air cleaner.
Re: Trick Flow intakes open for orders [Re: AndyF] #1995112
01/20/16 07:39 PM
01/20/16 07:39 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Good news, Chrysler had lots of hood scoops to choose from
Re: Trick Flow intakes open for orders [Re: AndyF] #1995158
01/20/16 09:36 PM
01/20/16 09:36 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I thought air cleaners restrict air flow. I have never had a air cleaner on anything I have raced.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Trick Flow intakes open for orders [Re: D-50] #1995165
01/20/16 09:57 PM
01/20/16 09:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Apparently they straighten/slow down air flow...........
Re: Trick Flow intakes open for orders [Re: BradH] #1995175
01/20/16 10:11 PM
01/20/16 10:11 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Your hood clearance is not what they are concerned about. They are more worried about their intake matching their heads for performance. You want something that sits low, won't make as much power and your hood close.......there are plenty of those already.
Re: Trick Flow intakes open for orders [Re: SpareParts] #1995200
01/20/16 11:02 PM
01/20/16 11:02 PM
jersey
Spaceman Spiff Offline
jersey
not for a '58 plymouth....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Trick Flow intakes open for orders [Re: Spaceman Spiff] #1995216
01/20/16 11:32 PM
01/20/16 11:32 PM
BradH Offline
BradH  Offline
Take an E-body Challenger, add a 440 based engine w/ raised-runner heads (Stage VIs w/ RB intake spacers or Victors), use a 14" x 3" drop-base air cleaner and cover the engine bay w/ a T/A replica hood. The amount of room for an intake manifold is limited by the RB block height and the raised-port heads pushing the intake up so much higher than an OEM-type head.
The Victors take up even more room than the Stage VIs w/ RB intake spacers. Whereas I could run an M1 w/ a 1" spacer or a Victor intake w/ no spacers, now I'm limited to an M1 w/ a 1/2" spacer and a Victor won't fit w/ even that low of an air cleaner setup.
So, I make a simple comment re: how the new Trick Flow intake is (unfortunately for my use) taller than I'd like since I can no longer fit a Victor under my scoop either, and the snarky comments and smart-a$$es have to come into the discussion. Thanks.
Re: Trick Flow intakes open for orders [Re: AndyF] #1995226
01/20/16 11:52 PM
01/20/16 11:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Enlarge the scoop dude!
Mopar to the bone!!!
Re: Trick Flow intakes open for orders [Re: D-50] #1995292
01/21/16 01:33 AM
01/21/16 01:33 AM
Puyallup, WA
Puyallup, WA
I went back to back runs a few years ago with & without air cleaner. Absolutely NO difference. And that's a drop base with a 3" element.
Re: Trick Flow intakes open for orders [Re: StealthWedge67] #1995352
01/21/16 03:01 AM
01/21/16 03:01 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I guess that is the reason Pro Stock runs air cleaners. Maybe they are worried about the weight.
Re: Trick Flow intakes open for orders [Re: 72Swinger] #1995354
01/21/16 03:04 AM
01/21/16 03:04 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Stop being snarky and smart-a$$ with your suggestions hahaha the skin is thin here! We're Lucky to have so many options available to us, ford guys have like one choice.
