Re: 1974 w200 440 4 speed fuel mileage questions. [Re: poorboy] #1993497
01/18/16 07:12 PM
01/18/16 07:12 PM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
Originally Posted By poorboy
I would replace the intake bathtub gasket. I've had more the one big block suck oil up into the intake runners from under that tin gasket, and I've had more the one leak at any one, or all 4 corners at the head to block corners when driving highway speeds or turning higher rpms. Gene
Valley pan gaskets are new. I used fiber gaskets on either side of the valley pan. Only thing I can think of is one bolt wouldn't torque to spec. It torqued to 25ftlbs but would not torque above that. Hmm
Re: 1974 w200 440 4 speed fuel mileage questions. [Re: magnum440d100] #1993729
01/18/16 11:34 PM
01/18/16 11:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I wouldn't use gaskets with the tin valley pan. It's meant to be used solo.
Re: 1974 w200 440 4 speed fuel mileage questions. [Re: DaytonaTurbo] #1993747
01/18/16 11:51 PM
01/18/16 11:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How do you seal the mating faces? Silicone?
Re: 1974 w200 440 4 speed fuel mileage questions. [Re: WO23Coronet] #1994592
01/20/16 01:08 AM
01/20/16 01:08 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yes, the blue stuff, on both sides of the head surface on the tin plate and on the block and corners of the block/head. Gene
Re: 1974 w200 440 4 speed fuel mileage questions. [Re: WO23Coronet] #1994812
01/20/16 12:21 PM
01/20/16 12:21 PM
Manitoba, Canada
Manitoba, Canada
I only use silicone under the front and real valley pan hold downs. Under the intake flanges I just mask them off and spray them with the copper gasket spray.
