1970 challenger wont start after sitting for a month #1993604
01/18/16 09:44 PM
01/18/16 09:44 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
No spark to the plugs. Has Mopar electronic distributor with orange box and stock coil. Ran fine when parked a month ago or so. Ideas?
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1993609
01/18/16 09:47 PM
01/18/16 09:47 PM
wooster ohio
3
3csalvage Offline
3csalvage  Offline
wooster ohio
low on spark fluid? whistling
Re: 1970 challenger wont start after sitting for a month [Re: 3csalvage] #1993613
01/18/16 09:48 PM
01/18/16 09:48 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Blinker fluid leaked onto the spark box thingie?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1993616
01/18/16 09:49 PM
01/18/16 09:49 PM
amxautox Offline
amxautox  Offline
Did you turn on the key? work
Tom
author unknown
Re: 1970 challenger wont start after sitting for a month [Re: amxautox] #1993622
01/18/16 09:55 PM
01/18/16 09:55 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Nice. Guess this is the wrong place to ask for help.
2021 T/A 392
2020 Hellcat redeye
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1993624
01/18/16 09:56 PM
01/18/16 09:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What have you done to diagnose the problem before asking for help? The board helps those that help themselves. boogie
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1993627
01/18/16 09:58 PM
01/18/16 09:58 PM
amxautox Offline
amxautox  Offline
Ya gotta remember we do a lot of joking around in the General Forum. Doesn't mean anything, just a fun place.
Just check all the connections for corrosion, and so on. And then test the units to see if the coil works, the ECU works, and so on. Normal diagnoses stuff.
It HAS been raining alot around here the past couple months so corrosion could be prominent. And Dec has been the wettest Dec. on record, if I remember correctly what they said the other day on the news.
Tom
author unknown
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1993724
01/18/16 11:27 PM
01/18/16 11:27 PM
Ideas?
Pull the yellow wire with tracer off of the "ign" terminal on the starter relay to disable the starter (no need to run the batt down). With a helper see if you have voltage at the coil positive terminal and the blue/yellow wire at the ECU pentastar connector in "run" and in "start". Likely you do but I would check (if not then clean the bulkhead). pull the coil wire (dist end) out and hold it 1/4" from ground and seperate the zigzag pull apart dist pickup connector & drag the male terminal on the body half across the metal intake surface & see if the coil wire sparks in "run" and in "crank". then take the wires/terminals off of the coil negative primary terminal (might just be one) and with a jumper with alligator clips connect one clip to that coil terminal (not to the wire you removed from the coil terminal) and drag the other alligator clip across the intake metal surface like before & see if the large coil wire sparks same as before in "run" and in "crank". Holler back. EDIT SWAG-its the orange box
Re: 1970 challenger wont start after sitting for a month [Re: RapidRobert] #1993799
01/19/16 12:47 AM
01/19/16 12:47 AM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Thanks, this is what I was looking for. I appreciate it. I will let you know what I find tomorrow.
2021 T/A 392
2020 Hellcat redeye
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1993850
01/19/16 01:39 AM
01/19/16 01:39 AM
Highland, MI.
Sunroofcuda Online content
Sunroofcuda  Online Content
Highland, MI.
Swap out the ballast resistor & see if that makes a difference. Happened on my old '71 Hemi Charger & we spent 2 weeks messing around with everything else before we discovered it was a $3.00 ballast!
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1993871
01/19/16 02:29 AM
01/19/16 02:29 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
I had a jeep I swapped a 318 into with mopar electronic ign. often after sitting for a week or so it had no spark. I just pulled one side of the ballast resister off and put it back on and wala spark. poor connection.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1994085
01/19/16 02:40 PM
01/19/16 02:40 PM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
Put a Chevy alternator on it. Seems like a common thing around here....
Re: 1970 challenger wont start after sitting for a month [Re: RapidRobert] #1994179
01/19/16 04:46 PM
01/19/16 04:46 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
I have voltage (10.8V) at the coil positive terminal and blue/yellow wire at the ECU. I get spark at the coil wire when I drag the zigzag connector and separate wire hooked to the negative terminal.
2021 T/A 392
2020 Hellcat redeye
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1994203
01/19/16 05:29 PM
01/19/16 05:29 PM
if the coil wire is sparking while dragging the male side of the body half of the connector across the intake with the key in "run" AND with the key being held to "start" then all is good in the 'hood ex the dist pickup ain't triggering the ECU for some reason. pickup coil continuity (grab your meter) or the mini screw for the dist upper flat plate come loose & let the plate/magnet slip away so the gap to the teeth is too great (want .008") or the intergear pin down below has shaeared (extremely unlikely). there could be poor contact between the metal terminals in the zigzag pull apart connector (pretty rare tho). if you have another dist (even a /6 one) plug it in to the zigzag connector & spin its shaft by hand & see if you get sparks. Short version: quick visual on the reluctor/magnet area for anything thats not right then grab your meter. EDIT I'm assuming the 10.8V is while cranking? I just had an issue on my ramcharger and after towed back home the coil would spark but would run bad. swapped the coil & all good. But yours is dead in the water. Keep us posted
Re: 1970 challenger wont start after sitting for a month [Re: RapidRobert] #1994342
01/19/16 08:51 PM
01/19/16 08:51 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
I had another distributor and put it in. The spark was a lot more pronounced spinning the engine over with the coil wire 1/4 from a grounding surface. It started right up after putting the coil wire back on. Everything inside the distributor looks fine, air gap etc. I assume the pick up failed?
Thanks for all the help. Its refreshing considering how this post started.
2021 T/A 392
2020 Hellcat redeye
Re: 1970 challenger wont start after sitting for a month [Re: moparfan] #1994347
01/19/16 09:05 PM
01/19/16 09:05 PM
Yeah on the dist if the teeth are in close proximity to the magnet there ain't much else that can go bad other than the pickup tho I would not have expected it to go belly up just from the sitting time. Might have happened right when it shut down last time. Yeah I was surprised with the contents also! and that is pretty much out of character for us as we are (pretty much) a bunch of Chrysler obsessed choir boys (with a few exceptions). The bad apples have vacated on their own or been run off by the moderators
Re: 1970 challenger wont start after sitting for a month [Re: RapidRobert] #1994365
01/19/16 09:38 PM
01/19/16 09:38 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Thanks again for the help.
2021 T/A 392
2020 Hellcat redeye
