Re: Cuda Metal Trim Restoration/Polishing Question
[Re: B5Cuda440-6]
#1993303
01/18/16 02:21 PM
01/18/16 02:21 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
Because 90% of the people on this board refer to every shiny part on a car as "CHROME", you are behind the eight ball from the get go. Those pieces you are referring to are stainless steel. And yes, if it is polished to a very high degree, it does look like it has been chrome plated! Unfortunately the best guy to do this, is no longer in business. www.alltrim.com Although his site is still up.
[Re: B5Cuda440-6]
#1993367
01/18/16 03:27 PM
01/18/16 03:27 PM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
I made these videos to help anyone that wants to polish stainless trim themselves. You can make stainless look like chrome or stop at any point you are happy with the look. The end of video 3 shows the before and after. Part 1 https://www.youtube.com/watch?v=wTxR8LB9iekPart 2 https://www.youtube.com/watch?v=nc1iY08HU7wPart 3 https://www.youtube.com/watch?v=mWy9awGv6soI do not do polishing work for others, but thought I would share in case you want to know how it's done. What I show in the videos is the way I do it. There are others ways to polish stainless too. I just enjoying sharing and helping others.
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
[Re: B5Cuda440-6]
#1993380
01/18/16 03:47 PM
01/18/16 03:47 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
If you ain't got anybody close, try here... Mcnichols Polishing & Anodizing Inc 12139 Woodbine Redford, MI 48239-2417 (313) 538-3470 www.mcnicholsanodizing.com
[Re: Cuda Cody]
#1993468
01/18/16 06:25 PM
01/18/16 06:25 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Yep, that process looks very familiar Cody. If you do enough cars, you learn to do much of that type of work in house because of the cost and needing the part NOW. I'm looking at a small mountain of stainless trim I will be starting very shortly for the pink tuna boat we are finishing up. Excellent video's Cody, nice work. Unless you do enough stainless trim restoration, you really don't have a clue the time it takes to do that good of a job. I did all the stainless on a 68 Charger only because the owner was a REALLY GOOD friend of mine.
[Re: autoxcuda]
#1993692
01/18/16 10:51 PM
01/18/16 10:51 PM
Posts: 1,913 central P.A.
HEMIDOG 70
central P.A.
I've done fine with a larger model Harbor Freight.
Those big floor mounted 3 phase pro buffers are great. Results are much faster. I've used one to do a bunch of stuff. Scary though. No thanks, I like all my fingers still attached to my hands. x2 I have a good friend who had a bad incident with a buffing wheel. A piece he was buffing kicked out of his hands and hit him right in the face. It almost amputated his nose. Thanks to a great plastic surgeon you cannot even see the damage now. He was very fortunate it wasn't worse. Gloves a face shield and a heavy or leather jacket would be some good items to wear if trying this at home.
[Re: B5Cuda440-6]
#1993906
01/19/16 04:37 AM
01/19/16 04:37 AM
maxfield303H1E
maxfield303H1E
Discolor or even burn through the piece. A friend of mine got a kit from Eastwood and tried it. He ended up burning right through the piece after it started to blue and then he said it acted like a welder and burned right through the spot.
[Re: Stanton]
#1994123
01/19/16 03:31 PM
01/19/16 03:31 PM
Posts: 369 Chicago
curbman68
Chicago
Well here's my 2 cents (from my personal experience)
If you do it yourself, invest in a BIG, quality Baldor buffer and the big wheels and the compound kit (TP Tools have a great package deal). Small, cheap Harbour Freight buffers and wheels just aren't up to the task.
Don't expect great results in a short timeframe. After you hit the first piece you're going to see a million scratches you didn't notice before. Each one has to be SANDED out with multiple grits before its ready to be buffed.
Dents are a whole other issue.
In the end you will have either: a) spent half your life buffing the stuff or b) wish you'd left well enough alone
Regardless, you'll have spent a bundle on tools and you will have a clear understanding why the guys who do it charge so much. Very well said, in my experience this is exactly right. I'll do small pieces myself, but am just fine paying someone else to do the rest
[Re: B5Cuda440-6]
#1994125
01/19/16 03:33 PM
01/19/16 03:33 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Discolor or even burn through the piece. A friend of mine got a kit from Eastwood and tried it. He ended up burning right through the piece after it started to blue and then he said it acted like a welder and burned right through the spot. Either your friend is a complete idiot who should not be allowed near power tools or this is total bullsh!t. I think its the latter ... there's no way a buffer will burn through a piece of stainless ... the buffer would catch fire long before that happens.
[Re: Stanton]
#1994617
01/20/16 01:35 AM
01/20/16 01:35 AM
maxfield303H1E
maxfield303H1E
he was using one of the expanding wheel sanding belts with a 400 grit. Pretty much part of the process of restoring stainless to get the part flat again. And yes, it was his first time doing it. Since then, he no longer does it and sold his stuff off to someone.
[Re: B5Cuda440-6]
#1994620
01/20/16 01:38 AM
01/20/16 01:38 AM
maxfield303H1E
maxfield303H1E
Also, are you saying that a buffing wheel can not generate enough heat to discolor a piece of stainless or other metal?
