oil sending sensor. #1992829
01/17/16 06:38 PM
01/17/16 06:38 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Is the oil sending sensor hard to get to and change on a 3.7 in a 04 Dakota?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: oil sending sensor. [Re: D-50] #1994589
01/20/16 01:06 AM
01/20/16 01:06 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
No, it's above the oil filter. If you need to remove filter. A deep socket around 15/16 will work.
Re: oil sending sensor. [Re: D-50] #1995269
01/21/16 12:51 AM
01/21/16 12:51 AM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thanks..
