70 Air Grabber Switch. #1991911
01/16/16 01:29 PM
01/16/16 01:29 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Is it correct that on a 70 Roadrunner or GTX, from the factory, a chrome handled air grabber switch was sometimes used instead of the red? I have seen the chrome one on a handful of cars but mainly red. The switch was missing on my Roadrunner 30 years ago when I bought it and back then I just put on a chrome.
Thanks !
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 70 Air Grabber Switch. [Re: TimS] #1991935
01/16/16 01:54 PM
01/16/16 01:54 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
It's a replacement switch that was a heater switch used a few years earlier on C-bodies. All switches were factory red. Here is what you have...
Re: 70 Air Grabber Switch. [Re: TimS] #1991936
01/16/16 01:55 PM
01/16/16 01:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I've only seen red. My 70 GTX the switch is red.
Re: 70 Air Grabber Switch. [Re: TimS] #1992039
01/16/16 04:19 PM
01/16/16 04:19 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
The lever was red plastic from the factory on production cars.
As stated the chrome plated one is a heater switch and body.
The correct red lever body will have this number 2947776
silk screened on.
Heater switch body does not have this but a different number cast into it but will do the job.
Re: 70 Air Grabber Switch. [Re: mccannix] #1992118
01/16/16 07:07 PM
01/16/16 07:07 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks the info. I see the chrome switches are advertised by some as air grabber switches but I thought that might not be the case. I've had 3 or 4 air grabber cars over the years and they all had red switches. I've got the correct red one to install on my Roadrunner.
Anyone need a chrome heater switch? It works great.
Re: 70 Air Grabber Switch. [Re: TimS] #2006976
02/06/16 09:25 PM
02/06/16 09:25 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
You could paint the switch handle red. Not many people would know the difference.
If you break off the nubs on the back I can repair them.
