Build Date #1991499
01/15/16 08:50 PM
01/15/16 08:50 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Can you tell from broadcast sheet when your car was built ?
thanks
Re: Build Date [Re: ct440rod] #1991524
01/15/16 09:38 PM
01/15/16 09:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nope.
Re: Build Date [Re: ct440rod] #1991722
01/16/16 01:49 AM
01/16/16 01:49 AM
Alabama
BigMoneyLewis Offline
Alabama
You can see the cars SPD ("Scheduled" production date) right in front of the VON (vehicle Order number) but it may not be the actual date the car was built .
Greg
gregward@mchsi.com phone 256-852-0955
Re: Build Date [Re: ct440rod] #1991758
01/16/16 03:00 AM
01/16/16 03:00 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
thanks
Maybe. At what plant was the car built?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Build Date [Re: ct440rod] #1991853
01/16/16 11:53 AM
01/16/16 11:53 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Hamtramck . or is there another way to tell. I took sticker off door 20 years ago when car was painted and not sure where it is right now.
Re: Build Date [Re: ct440rod] #1991938
01/16/16 01:57 PM
01/16/16 01:57 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
What year car is it?
Re: Build Date [Re: ct440rod] #1992049
01/16/16 04:33 PM
01/16/16 04:33 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
70 Challenger r/t 440 mag
Re: Build Date [Re: ct440rod] #1992137
01/16/16 07:39 PM
01/16/16 07:39 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
That's Barry's bailiwick. I can't help you.
Seeking:
Re: Build Date [Re: 69CoronetRT] #1993040
01/18/16 12:13 AM
01/18/16 12:13 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I've been working on an "Actual Production Date" vs. "Scheduled Production Date" calendar for a number of years/plants. This might be a bit pre-mature, but I currently have March 17 - April 15 mapped out for '70 Hamtramck assembly line #1 (EN1).
IF the OP's R/T SE falls in this range (~8,000 cars) I think I can answer the question - at this point - maybe grin
so, what's the SPD?
can you share a copy of the b'cast sheet? dhead68AThotmail.com
Re: Build Date [Re: ct440rod] #1993140
01/18/16 03:51 AM
01/18/16 03:51 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You'll have an estimate of when it was actually built. Your door sticker would tell you the month.
Re: Build Date [Re: ct440rod] #1993366
01/18/16 03:26 PM
01/18/16 03:26 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
