bronze lifter bores #1989055
01/12/16 02:53 AM
01/12/16 02:53 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
To get the proper lifter clearance on bronze bushings , do you hone or ream them to size. On a aluminum block I read it should be .0015 to.002 , is that correct? I'm using Jesel tool steel tie bar roller lifters if that makes a difference.
Re: bronze lifter bores [Re: rowin4] #1989206
01/12/16 01:54 PM
01/12/16 01:54 PM
Call Jesel and ask them, I would want to know the exact aluminum alloy of the block first so I could let them know. Different aluminum alloys like used in pistons, and if heat treated, expand differently than other aluminum alloys work
Re: bronze lifter bores [Re: rowin4] #1989216
01/12/16 02:02 PM
01/12/16 02:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I changed a set of bushing in one of my engines..
after pushing them in.. I used a reamer to set my
spec.. but I have no clue for your alum block for
what your spec would be
wave
Re: bronze lifter bores [Re: rowin4] #1989465
01/12/16 08:34 PM
01/12/16 08:34 PM
rowin4 Offline OP
rowin4  Offline OP
Good Idea on contacting Jesel, as the lifters are a combination of steel and aluminum, that might make a difference also.
Re: bronze lifter bores [Re: rowin4] #1989510
01/12/16 10:07 PM
01/12/16 10:07 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
.0015-.002 sounds a tad loose to me.
Re: bronze lifter bores [Re: rowin4] #1989661
01/13/16 01:12 AM
01/13/16 01:12 AM
rowin4 Offline OP
rowin4  Offline OP
Sent a E-Mail to Jesel tech to clear up what is stated in their tech section on lifter bore tolerances. Looks like .002 we'll see what they come back with.
Re: bronze lifter bores [Re: rowin4] #1989754
01/13/16 06:17 AM
01/13/16 06:17 AM
It would real interesting to measure the lifter bores at room temps and then use a heat gun or propane torch to heat the same lifter bores up to 160+ F or above and see how much bigger that hole gets work scope thumbs twocents that would be one of those things to make sure you don't rev the motor up much when cold or not warmed up if you set them up at .0010 or tighter cold work
Re: bronze lifter bores [Re: rowin4] #1989881
01/13/16 02:24 PM
01/13/16 02:24 PM
rowin4 Offline OP
rowin4  Offline OP
Getting off the roller lifter subject , we all have heard of the to tight of lifter bores not letting the lifter rotate in our stock blocks causing the wiping out our solid flat tappet lifters. What should the clearance be for a standard lifter in a iron block?
Re: bronze lifter bores [Re: rowin4] #1990120
01/13/16 07:50 PM
01/13/16 07:50 PM
All the stock used Mopar V8 I've check are .0020+ shruggy Mopar, Direct Connection, use to sell oversized solid lifters for tightening up the clearances on stock blocks work shruggy
Some of the stock production 318,340 and 360 motors where machined with some of the lifter bores not 90 degrees front to rear to the cam tunnel runaway I'm assuming that those lifters couldn't, wouldn't or didn't rotate or spin proeperly work
Re: bronze lifter bores [Re: Cab_Burge] #1991260
01/15/16 02:24 PM
01/15/16 02:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
"Got a E-Mail back from Jesel. Jesel stated lifter clearance on aluminum block with bushed lifter bores should be .002 - .0025 and if you have a aluminum block without bushings .001 - .0015 also , the un-bushed block should be preheated before starting. That .0025 seems a little much . I'll see if I can keep it closer to .002"
Mine are .0025 Jesel Keyway and custom Jesel bushing with an aluminum block
