Re: clutch for built /6
[Re: cmcgee123]
#199099
01/20/09 09:58 PM
01/20/09 09:58 PM
Posts: 20,196 Park Forest, IL
slantzilla
Park Forest, IL
No, a stock rebuilt clutch will not be enough, and neither will a stock flywheel. A couple of the stick guys have had clutch/flywheel explosions in the last couple years. Go to www.slantsix.org and check in the Transmission section. There was a deal going on for a good clutch and maybe flywheel from Specclutch I think.
[Re: cmcgee123]
#199102
01/21/09 12:08 PM
01/21/09 12:08 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
im putting a 225 slant in a friends demon 4sp. the motor has a milled and p+p head mp purple cam clifford 4v intake and header. is a stock replacement clutch good enough? any part#s for a better clutch would help also.
It probably would be a good idea to go to the 10" truck clutch instead of the 9.25" clutch used in cars regardless of what brand you choose.
