prop valve application
#199038
01/20/09 04:28 PM
01/20/09 04:28 PM
340dart4spd
Parts Problem
Parts Problem
Re: prop valve application
[Re: RobX4406]
#199040
01/20/09 08:32 PM
01/20/09 08:32 PM
Posts: 211 ILL
Greentween
ILL
[Re: RobX4406]
#199041
01/20/09 08:35 PM
01/20/09 08:35 PM
340dart4spd
Parts Problem
Parts Problem
It's Not a 73-76 A body prop valve.
More like an FMJ Worth 25-35 at best.
was sold with s 73up large bolt conversion.......
[Re: 340dart4spd ]
#199042
01/20/09 09:24 PM
01/20/09 09:24 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
73-76 used the brass prop valve. Pirate site is incorrect. It may work and valve correctly, not the right valve from an appearance standpoint. Here's what a 73-76 A body disc prop valve looks like:
[Re: RobX4406]
#199043
01/21/09 03:38 PM
01/21/09 03:38 PM
340dart4spd
Parts Problem
Parts Problem
[Re: 4BBodies]
#199046
01/21/09 05:26 PM
01/21/09 05:26 PM
340dart4spd
Parts Problem
Parts Problem
'73 B Body, it's the same one as on my Roadrunner. Bracket may be a tad different, but the prop valve is identical.
will it work on a 73 a body street car.....not concerned with being correct
[Re: nomore65BelvJim]
#199048
01/22/09 08:55 AM
01/22/09 08:55 AM
340dart4spd
Parts Problem
Parts Problem
what calipers are you using? what rear brakes?
single piston on front stock one I think.. and drums on rear 8 3/4 10inch
