prop valve application #199038
01/20/09 04:28 PM
01/20/09 04:28 PM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
id please
Re: prop valve application [Re: 340dart4spd ] #199039
01/20/09 04:31 PM
01/20/09 04:31 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
It's Not a 73-76 A body prop valve.
More like an FMJ Worth 25-35 at best.
Re: prop valve application [Re: RobX4406] #199040
01/20/09 08:32 PM
01/20/09 08:32 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Re: prop valve application [Re: RobX4406] #199041
01/20/09 08:35 PM
01/20/09 08:35 PM
3
Parts Problem
Parts Problem
3
was sold with s 73up large bolt conversion.......
Re: prop valve application [Re: 340dart4spd ] #199042
01/20/09 09:24 PM
01/20/09 09:24 PM
RobX4406 Offline
RobX4406  Offline
73-76 used the brass prop valve.
Pirate site is incorrect. It may work and valve correctly, not the right valve from an appearance standpoint.
Here's what a 73-76 A body disc prop valve looks like:
Re: prop valve application [Re: RobX4406] #199043
01/21/09 03:38 PM
01/21/09 03:38 PM
3
Parts Problem
Parts Problem
3
must be aftermarket job
Re: prop valve application [Re: 340dart4spd ] #199044
01/21/09 04:18 PM
01/21/09 04:18 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
'73 B Body, it's the same one as on my Roadrunner. Bracket may be a tad different, but the prop valve is identical.
Re: prop valve application [Re: 340dart4spd ] #199045
01/21/09 04:20 PM
01/21/09 04:20 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
your picture looks like an F,M,J and possibly late B (73-74) "stock" unit. Never seen an A body unit that looks like it, original or aftermarket.
Re: prop valve application [Re: 4BBodies] #199046
01/21/09 05:26 PM
01/21/09 05:26 PM
3
Parts Problem
Parts Problem
3
will it work on a 73 a body street car.....not concerned with being correct
Re: prop valve application [Re: 340dart4spd ] #199047
01/21/09 05:30 PM
01/21/09 05:30 PM
what calipers are you using? what rear brakes?
Re: prop valve application [Re: nomore65BelvJim] #199048
01/22/09 08:55 AM
01/22/09 08:55 AM
3
Parts Problem
Parts Problem
3
single piston on front stock one I think.. and drums on rear 8 3/4 10inch
