Re: Best Oil to use on 440 with stroker kit, new rebuild?
[Re: batt2rm]
#1990236
01/13/16 10:18 PM
01/13/16 10:18 PM
Posts: 2,857 Pattison Texas
CSK
Pattison Texas
i run VR1 Valvoline 30wt in my 512.
[Re: batt2rm]
#1990284
01/13/16 11:21 PM
01/13/16 11:21 PM
maxfield303H1E
maxfield303H1E
another vote for the Valvoline VR1 stuff. They even now make it in synthetic too !
[Re: CSK]
#1990356
01/14/16 01:23 AM
01/14/16 01:23 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
i run VR1 Valvoline 30wt in my 512. I lost 2 hydraulic flat tappet cams last year using this oil.......
[Re: RJS]
#1990372
01/14/16 01:42 AM
01/14/16 01:42 AM
Posts: 422 wisconsin united states
keith airgrabber
Right in the Nutz!!!
I started and broke mine in on Brad Penn straight 30W because it is one of the highest with Zinc content. Then after that been using Brad Penn 20W-50. Ron I second that Brad Penn is in my 505. Great stuff
[Re: batt2rm]
#1990380
01/14/16 01:57 AM
01/14/16 01:57 AM
Posts: 43,162 Bend,OR USA
Cab_Burge
On all the street and strip stroker motors I build with either a solid roller lifter or hydraulic roller lifter I use Valvoline 5W 20WT non synthetic oil There are better and worst oils out there, that Valvoline oil has worked well for me for a lot of years so far with no additives On non roller lifter motors I use Comp Cams zinc oil additive on every oil change Lucas and Red Line sell a zinc additive also as well as a lot of other brands out there that work well so use the one you like the most
[Re: Cab_Burge]
#1990388
01/14/16 02:05 AM
01/14/16 02:05 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
On all the street and strip stroker motors I build with either a solid roller lifter or hydraulic roller lifter I use Valvoline 5W 20WT non synthetic oil There are better and worst oils out there, that Valvoline oil has worked well for me for a lot of years so far with no additives On non roller lifter motors I use Comp Cams zinc oil additive on every oil change Lucas and Red Line sell a zinc additive also as well as a lot of other brands out there that work well so use the one you like the most I use Rotello 15/40 with a zinc additive with my stroker
Abe Lincoln
[Re: batt2rm]
#1990449
01/14/16 04:00 AM
01/14/16 04:00 AM
RapidRobert
Hi was wonder what oil most guys are using on a new rebuilt 440 OT, have you fired it yet for breakin?
[Re: batt2rm]
#1990501
01/14/16 09:49 AM
01/14/16 09:49 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
My friend had a blueprint engine from Summit. Brke it in with high zinc, then switched to synthetic. Ruined the cam in a couple thousand miles. Keep zinc in the oil....
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: batt2rm]
#1990507
01/14/16 10:24 AM
01/14/16 10:24 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Ask the engine builder that put it together. He knows what clearances it has, and most likely has a preferred weight and brand.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: DaytonaTurbo]
#1990584
01/14/16 01:16 PM
01/14/16 01:16 PM
dart4forte
Mesa, Arizona
I don't have the race experience of some other guys on this board, however I am an Amsoil fan. They make an oil called Z-Rod which as you may guess by the name, is aimed at flat tappet engines. An oil analysis I read at one point showed it had very high levels of zinc in(higher than VR1 and Joe Gibbs), it as well as some other additive that helps prevent corrosion during long term storage. That's some good stuff. I'm thinking of switching in the GTS.
Abe Lincoln
