2002 1500 4.7 freeze plug help #1988399
01/11/16 01:32 PM
01/11/16 01:32 PM
nc
E
earthmover Offline OP
E
nc
Ok guys 4.7 freeze plug has a hole in the middle of it can't really get to it easy...it's the 1 on the side of the block under the heads ..what size is it and do the make those screw in type...can't really see a good way to get a regular 1 in there from the bottom don't want to have to pull it ..thanks
Re: 2002 1500 4.7 freeze plug help [Re: earthmover] #1988434
01/11/16 02:30 PM
01/11/16 02:30 PM
md
mopars4ever Offline
mopars4ever  Offline
md
They make the rubber expandable type but I would not leave it as a permanent fix.
Re: 2002 1500 4.7 freeze plug help [Re: mopars4ever] #1988578
01/11/16 04:38 PM
01/11/16 04:38 PM
nc
E
E
nc
Thanks do you know the size
Re: 2002 1500 4.7 freeze plug help [Re: earthmover] #1989738
01/13/16 03:39 AM
01/13/16 03:39 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i replaced all the freeze plugs in a 2000 durango 4.7 and they were 1 3/8,someone had put rubber 1 1/4 in it and they blew out!i used a hole saw to get access under a motor mount,i used the copper/brass plugs with the expanding nut in the middle,they work excellant but are not real easy to find
my ladder of success is missing some rungs
Re: 2002 1500 4.7 freeze plug help [Re: earthmover] #1989945
01/13/16 03:58 PM
01/13/16 03:58 PM
Guitar Jones Offline
My advise would be to pull it out and replace them all. The coolant hasn't been taken care of so others are going to be rotted out as well.
Re: 2002 1500 4.7 freeze plug help [Re: earthmover] #1991396
01/15/16 05:59 PM
01/15/16 05:59 PM
South Florida
indcontrols Offline
indcontrols  Offline
South Florida
Ditto, I did the hole saw trick on my buddy's, replaced one and about 3 months later, another one started leaking, had to pull it and replace them all.
