Re: Flexplate Question
[Re: None2Slow]
#198930
01/20/09 04:58 PM
01/20/09 04:58 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Get the B&M flex plate made for a external balance 360. They are made with a weight compensating cut out. OEM the weights are on the converter, not the flexplate. Using the B&M plate you DO NOT use, need, or want the weighted converter.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
