Re: Torque wrench
[Re: FastOne]
#1988083
01/11/16 12:20 AM
01/11/16 12:20 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Snapon, wright tool (snapon industrial), CDI, some craftsman. What range? Digital is nice but replacing the batteries is a pain in the butt. I prefer the click type. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Torque wrench
[Re: FastOne]
#1988108
01/11/16 12:51 AM
01/11/16 12:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
When I was working we had to have all our torque wrenches calibrated every year or so (no more than every other year).. I use to bring mine in to have them checked also.. I have 4 torque wrenches..most are clicker type.. and 1 beam.. at the moment I cant recall what brand names they all are(too many beers I guess.. or CRS).. any torque wrench should be calibrated to verify what you have... that includes new ones.. the last time mine were done was 5 years ago now.. I should have them checked again
Re: Torque wrench
[Re: Jeremiah]
#1988187
01/11/16 02:09 AM
01/11/16 02:09 AM
astjp2
Utah and Alaska
Get the digital, vibrating Snap-on. Once you use it and compare to a click type wrench you will see why. They are way more repeatable, for one thing. I have 3 assigned to me at work, I am constantly changing batt. inconsistent readings when the batteries get low. Not prone to failures with a mechanical click if they are taken of.
Re: Torque wrench
[Re: astjp2]
#1988198
01/11/16 02:23 AM
01/11/16 02:23 AM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
Get the digital, vibrating Snap-on. Once you use it and compare to a click type wrench you will see why. They are way more repeatable, for one thing. I have 3 assigned to me at work, I am constantly changing batt. inconsistent readings when the batteries get low. Not prone to failures with a mechanical click if they are taken of. Why are the batteries always dying? My shop stays between 60-75 degrees and I have not had an issue. Same goes for my machine shop. I'll have to check this out.
Re: Torque wrench
[Re: Jeremiah]
#1988219
01/11/16 02:57 AM
01/11/16 02:57 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I remove the batteries from my Snap-on wrench after every use too. It only takes a second.
Re: Torque wrench
[Re: FastOne]
#1988256
01/11/16 04:33 AM
01/11/16 04:33 AM
Posts: 4,525 Daisyland USA
jnkgal
Daisyland USA
I just bought one at Sears craftsman they had a huge sale on them recently
"A goal without a plan is just a wish."
Re: Torque wrench
[Re: FastOne]
#1988263
01/11/16 05:33 AM
01/11/16 05:33 AM
astjp2
Utah and Alaska
My Coworkers and I share the Tq wrenches, I have a hard time having them put it back in the tool box let alone take out the batteries. I go through a set every couple of months but its a pain if the tool crib is closed, I work nights making it more of a challenge. THe craftsman wrench I own, is digital, my shop is only heated when I am in it, so the fancy watch batteries only last a year. The snapon ones are at least AA batteries. I prefer just a clicker, sometimes when its noisy in the shop, you may not feel the buzzing or hear the beep that the snapon ones use. For me simple is good.
As for dial wrenches, the only thing I use them for is determining the run-on torque, beam torque wrenches are fairly accurate, just not as nice as a clicker that you just set and turn. I use torque wrenches a lot, from aircraft to machine maintenance, ease of use is something I cherish. Tim
Re: Torque wrench
[Re: astjp2]
#1988351
01/11/16 12:20 PM
01/11/16 12:20 PM
Jeremiah
Rogue River, OR
As for dial wrenches, the only thing I use them for is determining the run-on torque, beam torque wrenches are fairly accurate, just not as nice as a clicker that you just set and turn. I use torque wrenches a lot, from aircraft to machine maintenance, ease of use is something I cherish. Tim 3rd shift? Cold shop? You aint living right! All kidding aside, my new routine is to yank the batteries. Thanks again for heads up.
Re: Torque wrench
[Re: FastOne]
#1988834
01/11/16 09:47 PM
01/11/16 09:47 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have 7 or 8 in the box, all Snap-On, 1/4 3/8 and 1/2 drive, some dial, some click. Nothing with batteries. Some are 30 plus years old. Right tool for the job. I use a torque wrench on most fasteners on the engine, trans and rear. Some other critical places too, brakes, etc. I like the dial type for smaller stuff, trans band adjustment, checking bearing preloads, etc. Click style for the heavier fasteners. Get the tool serviced every few years, use the right lube, torque sequence and number of steps.
eBay is your friend for finding new or mint top shelf tools at affordable prices.
Re: Torque wrench
[Re: DavidDean]
#1988871
01/11/16 10:34 PM
01/11/16 10:34 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I had mine checked at ARP's display in Dallas. I found my craftsman click style was low by about 8 ft lbs at 80. My Harbor digital electronic torque meter was dead nuts on the money. The ARP guy didn't say much.Go figure. My 'thrifty' clicker from HF matches my beam...
Re: Torque wrench
[Re: FastOne]
#1988930
01/11/16 11:39 PM
01/11/16 11:39 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
Don't buy a cheap one, unless your really feeling lucky that day I have several early 1/2 inch drive beam types, a 1/2 inch drive Proto clicker, a newer Snap On 1/2 inch clicker that failed early last year, Several inch lbs wrenches, a small Proto 3/8 drive clicker that goes up to 150 inc lbs, another better brand 3/8 drive clicker that goes up to 700 inch lbs and a Proto 1/4 drive beam type 0 to 150 inch lbs for checking rotational torque when setting up rear ends for bearing preload. I should compare my clicker Snap On to the Proto clicker to see how close they are now that I had to pay to have the Snap On calibrated after the repairs to fx it and then compare both of my 1/2 inch beam types to see if there close to the clickers or not
