Torque wrench #1988069
01/11/16 12:01 AM
01/11/16 12:01 AM
FastOne Offline OP
FastOne  Offline OP
I want to get a new torque wrench, any suggestions on brand name & type most welcome
Re: Torque wrench [Re: FastOne] #1988083
01/11/16 12:20 AM
01/11/16 12:20 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Snapon, wright tool (snapon industrial), CDI, some craftsman. What range? Digital is nice but replacing the batteries is a pain in the butt. I prefer the click type. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Torque wrench [Re: astjp2] #1988091
01/11/16 12:32 AM
01/11/16 12:32 AM
FastOne Offline OP
FastOne  Offline OP
Oh about 150 - 200 lbs range
Have seen the digital type
What about the dial type?
Warren & Brown?
Re: Torque wrench [Re: FastOne] #1988108
01/11/16 12:51 AM
01/11/16 12:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When I was working we had to have all our torque
wrenches calibrated every year or so (no more than
every other year).. I use to bring mine in to have
them checked also.. I have 4 torque wrenches..most
are clicker type.. and 1 beam.. at the moment I cant
recall what brand names they all are(too many beers
I guess.. or CRS).. any torque wrench should be calibrated
to verify what you have... that includes new ones.. the
last time mine were done was 5 years ago now.. I should
have them checked again
wave
Re: Torque wrench [Re: FastOne] #1988114
01/11/16 12:53 AM
01/11/16 12:53 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Get the digital, vibrating Snap-on. Once you use it and compare to a click type wrench you will see why. They are way more repeatable, for one thing.
Re: Torque wrench [Re: Jeremiah] #1988187
01/11/16 02:09 AM
01/11/16 02:09 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I have 3 assigned to me at work, I am constantly changing batt. inconsistent readings when the batteries get low. Not prone to failures with a mechanical click if they are taken of.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Torque wrench [Re: FastOne] #1988193
01/11/16 02:15 AM
01/11/16 02:15 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Matco here. I'm quite frugal, but that's one place I won't cut corners.
Yeah, it's got a smallblock.
Re: Torque wrench [Re: astjp2] #1988198
01/11/16 02:23 AM
01/11/16 02:23 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Why are the batteries always dying? My shop stays between 60-75 degrees and I have not had an issue. Same goes for my machine shop. I'll have to check this out.
Re: Torque wrench [Re: Jeremiah] #1988219
01/11/16 02:57 AM
01/11/16 02:57 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I remove the batteries from my Snap-on wrench after every use too. It only takes a second.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Torque wrench [Re: FastOne] #1988220
01/11/16 02:57 AM
01/11/16 02:57 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cheapo from Kragens and compared it to my friends big bucks Snap on and was within 2-3 ft. lbs. so good enuff for me and have built a few motors including mine.............And I also don`t use stretch gauges on rod bolts either.......... beer
Re: Torque wrench [Re: FastOne] #1988244
01/11/16 03:50 AM
01/11/16 03:50 AM
South Australia
Retroboy Offline
Retroboy  Offline
South Australia
Warren & Brown are a premium quality tool that will last a life time. I've had mine since 1974.
Cheers
Tony
Re: Torque wrench [Re: FastOne] #1988256
01/11/16 04:33 AM
01/11/16 04:33 AM
Daisyland USA
jnkgal Offline
jnkgal  Offline
Daisyland USA
I just bought one at Sears
craftsman
they had a huge sale on them recently
"A goal without a plan is just a wish."
Re: Torque wrench [Re: FastOne] #1988263
01/11/16 05:33 AM
01/11/16 05:33 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My Coworkers and I share the Tq wrenches, I have a hard time having them put it back in the tool box let alone take out the batteries. I go through a set every couple of months but its a pain if the tool crib is closed, I work nights making it more of a challenge. THe craftsman wrench I own, is digital, my shop is only heated when I am in it, so the fancy watch batteries only last a year. The snapon ones are at least AA batteries. I prefer just a clicker, sometimes when its noisy in the shop, you may not feel the buzzing or hear the beep that the snapon ones use. For me simple is good.
As for dial wrenches, the only thing I use them for is determining the run-on torque, beam torque wrenches are fairly accurate, just not as nice as a clicker that you just set and turn. I use torque wrenches a lot, from aircraft to machine maintenance, ease of use is something I cherish. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Torque wrench [Re: astjp2] #1988302
01/11/16 10:23 AM
01/11/16 10:23 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have a Craftsman that is giving a n error message, the problem is most Sears stores don't know anything about how to send them off to get them fixed. Even then it $60 to $80 up front to send one in then to find out that it's not repairable. In the Air Force we had them recalibrated every 90 days or if one was dropped.
Re: Torque wrench [Re: astjp2] #1988351
01/11/16 12:20 PM
01/11/16 12:20 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
3rd shift? Cold shop?
You aint living right!
All kidding aside, my new routine is to yank the batteries. Thanks again for heads up.
Re: Torque wrench [Re: Jeremiah] #1988791
01/11/16 08:47 PM
01/11/16 08:47 PM
dogdays Offline
dogdays  Offline
A couple of years ago I went manic and bought a number of Snap-On dial torque wrenches in various sizes. They work in a manner that is repeatable. You twist a steel torsion member and an arm moves a dial indicator. Nothing to change.
Two things I don't like them for:
1. Quick work. They can't be rushed. Plus no ratchet.
2. Odd places or work arrangements. They require one to be able to spot the dial from the top and are kind of bulky.
For those jobs I use my trusty Montgomery Ward click type.
The beam type is very accurate if it is built correctly.
R.
Re: Torque wrench [Re: FastOne] #1988823
01/11/16 09:32 PM
01/11/16 09:32 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I had mine checked at ARP's display in Dallas. I found my craftsman click style was low by about 8 ft lbs at 80. My Harbor digital electronic torque meter was dead nuts on the money. The ARP guy didn't say much.Go figure.
Re: Torque wrench [Re: FastOne] #1988834
01/11/16 09:47 PM
01/11/16 09:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have 7 or 8 in the box, all Snap-On, 1/4 3/8 and 1/2 drive, some dial, some click. Nothing with batteries. Some are 30 plus years old. Right tool for the job. I use a torque wrench on most fasteners on the engine, trans and rear. Some other critical places too, brakes, etc. I like the dial type for smaller stuff, trans band adjustment, checking bearing preloads, etc. Click style for the heavier fasteners. Get the tool serviced every few years, use the right lube, torque sequence and number of steps.
eBay is your friend for finding new or mint top shelf tools at affordable prices.
Re: Torque wrench [Re: DavidDean] #1988871
01/11/16 10:34 PM
01/11/16 10:34 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
My 'thrifty' clicker from HF matches my beam...
Re: Torque wrench [Re: FastOne] #1988930
01/11/16 11:39 PM
01/11/16 11:39 PM
Don't buy a cheap one, unless your really feeling lucky that day twocentsI have several early 1/2 inch drive beam types, a 1/2 inch drive Proto clicker, a newer Snap On 1/2 inch clicker that failed early last year, runaway Several inch lbs wrenches, a small Proto 3/8 drive clicker that goes up to 150 inc lbs, another better brand 3/8 drive clicker that goes up to 700 inch lbs and a Proto 1/4 drive beam type 0 to 150 inch lbs for checking rotational torque when setting up rear ends for bearing preload.
I should compare my clicker Snap On to the Proto clicker to see how close they are now that I had to pay to have the Snap On calibrated after the repairs to fx it and then compare both of my 1/2 inch beam types to see if there close to the clickers or not work
