How do you tell a manual steering from power steering column #1987846
01/10/16 07:53 PM
01/10/16 07:53 PM
Everywhere
Lost in life Offline OP
Everywhere
Specifically how do you differentiate between a manual steering column from a power steering column in 67-69 A body? Can the power column be modified for a manual steering box? Thanks
Re: How do you tell a manual steering from power steering column [Re: Lost in life] #1987860
01/10/16 08:06 PM
01/10/16 08:06 PM
PA
70Duster Offline
70Duster  Offline
PA
The steering shaft is shorter on the power steering column. You can always swap just the shaft from a manual column to the power steering column if you want to change the original power steering column to work with a manual steering box.
Re: How do you tell a manual steering from power steering column [Re: Lost in life] #1987874
01/10/16 08:13 PM
01/10/16 08:13 PM
Everywhere
Everywhere
Thank you for the reply...appreciate the insight.
Re: How do you tell a manual steering from power steering column [Re: 70Duster] #1987875
01/10/16 08:13 PM
01/10/16 08:13 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There is an adapter that is made to use the power steering column in a manual steering A-Body.
http://www.manciniracing.com/search-resu...p;Submit=Search
JB Rhinehart, Realist
A-Body's RULE!
Re: How do you tell a manual steering from power steering column [Re: Lost in life] #1987930
01/10/16 09:48 PM
01/10/16 09:48 PM
SC
Southern Wolf Offline
SC
What is the length of the manual shaft?
